Chopper towing sensor, what is the tension?
In summary, the problem involves finding the tension on a cable towing a sensor attached to a helicopter flying at a constant altitude. Both the helicopter and sensor have a horizontal acceleration of 2.84 m/s2. To find the tension, we use the equation T= mg + ma, but since the acceleration is horizontal, we must consider the direction of the forces. To add vectors, we can use a diagram and basic geometry principles.
broginator
A helicopter is flying at a constant altitude towing an airborn laser at 129kg. Both the chopper and the sensor move only horizontaly and have a acceleration of magnitude 2,84 m/s2. ignoring air restitance find the tension on the cable towing the sensor.
T= mg + ma
T=129kg x 9,8 m/s2 + 129kg x 2,84 m/s2.
this equation only work if the chopper were flying vertical.
The right answer is 130N but need to know how to get there.
Try drawing a diagram and identify the forces on the "laser"
broginator said:
T= mg + ma
That is true as a vector equation, but if you mean as scalars then you have to worry about direction. Which way is the acceleration? Do you know how to add vectors?
Likes 2nafish117
the acceleration is horizontal so it is orthogonal. no don't know how to ad vetors, we are having 1 chapter a day and my math skills are shitty so can't quite hold on the pace..
It's just like adding displacements that need not be in the same straight line. If you go 1m N then 2m E (not too near the poles!) how far are you from your start point?
[edit] comment removed
Related to Chopper towing sensor, what is the tension?
1. What is a chopper towing sensor?
A chopper towing sensor is a device used to measure the tension or force being applied to a rope or cable during towing. It is typically used in marine applications to ensure the safety and efficiency of towing operations.
2. How does a chopper towing sensor work?
A chopper towing sensor works by using strain gauges or load cells to detect the amount of force being applied to the towing rope. This information is then converted into an electrical signal that can be read and analyzed by a computer or other device.
3. What is the purpose of a chopper towing sensor?
The purpose of a chopper towing sensor is to ensure that the tension on the towing rope is within safe and optimal levels. It helps prevent overloading or underloading, which can cause damage to the towing equipment, vessel, or cargo.
4. How accurate are chopper towing sensors?
The accuracy of chopper towing sensors can vary depending on the specific model and manufacturer. However, most sensors are designed to provide precise and reliable measurements, with an accuracy of within 1-2% of the actual tension.
5. Are there different types of chopper towing sensors?
Yes, there are different types of chopper towing sensors available, including mechanical, hydraulic, and electronic sensors. Each type has its own advantages and disadvantages, and the best one to use will depend on the specific towing application and requirements.
