Christoffel symbols and Geodesic equations.
In summary, the conversation discusses a 2-dimensional manifold with a given line element and explores its properties. It is determined that the line element is well defined for all values of y and z, except for z=0. The non-vanishing Christoffel symbols and the geodesic equations are obtained. The conversation also discusses solving the geodesic equations and suggests an improved coordinate system. It is mentioned that there is no general method for solving differential equations, but there are various resources available online. Finally, the conversation addresses a clarification regarding a change of variables.
trv
73
(a) Consider a 2-dimensional manifold M with the following line element
ds2=dy2+(1/z2)dz2
For which values of z is this line element well defined.
(b) Find the non-vanishing Christoffel symbols
(c) Obtain the geodesic equations parameterised by l.
(d) Solve the geodesic equations and suggest an improved coordinate system. What is the metric in the new coordinates? What lines describ the geodesic geometrically?
(e) What can you say about the Riemann curvature tensor, the Ricci tensor and the Ricci scalar of this manifold.
(a) The line element is well defined for all values of y and z other then z=0
(b) gzz,z= -2/z3
The only non vanishing christoffel symbol is,
Czzz= -1/z
(c) The geodesic equations are given by,
d2z/(dl2)-(1/z)(dz/dl2)=0
(d)
d2z/dl2=(1/z)(dz/dl2)
Stuck here.
To solve the differential equation in (d), try the change of variables z=e^v. Think about applying this change of variables to the original coordinate system.
Hey Dick thanks for the hint. Haven't managed to get anywhere with it yet, but will give it a go again tomorrow.
If I may ask you another question however,...is there a general method for solving the differential equations/geodesic equations? If so it would be really useful if you guide me to an online resource for the same.
For some forms of differential equations there are methods specific to that form. But there is no one method. There's tons of stuff online. Just google 'solving differential equations' and pick your favorite.
Hi dick, could you possibly have meant e^l rather than e^v?
No, I meant substitute z(l)=e^(v(l)). What does the differential equation for v(l) look like?
Related to Christoffel symbols and Geodesic equations.
1. What are Christoffel symbols?
Christoffel symbols are a set of coefficients used in the study of differential geometry. They are used to represent the connections between different points on a curved surface, and are an essential tool in understanding the geometry of a manifold.
2. How are Christoffel symbols calculated?
Christoffel symbols are typically calculated using the metric tensor, which describes the distance between neighboring points on a manifold. By taking derivatives of the metric tensor, the Christoffel symbols can be obtained.
3. What are geodesic equations?
Geodesic equations are a set of equations that describe the shortest path between two points on a curved surface. They are used to find the geodesic, or the path of least resistance, on a manifold.
4. How are geodesic equations related to Christoffel symbols?
Geodesic equations involve the use of Christoffel symbols, as they are used to calculate the curvature and connections between points on a manifold. The Christoffel symbols are necessary for solving the geodesic equations.
5. What is the significance of Christoffel symbols and geodesic equations?
Christoffel symbols and geodesic equations are essential tools in the study of differential geometry and have numerous applications in physics and engineering. They allow for the understanding and calculation of the curvature and connections between points on curved surfaces, and can be used in fields such as general relativity and robotics.
9K
