Christoffel symbols of Schwarzschild metric with Lagrangian
In summary, the Schwarzschild metric is given by ds2=-(1-2M/r)dt2+(1-2M/r)-1dr2+r2dθ2+r2sin2θ dφ2and the Lagragian is ##{\frac{d}{dσ}}[{\frac{1}{L}}{\frac{dx^α}{dσ}}] + {\frac{∂L}{∂x^α}}=0##with L = dτ/dσ. So for each α=0,1,2,3 we have##{\frac{d^2 x^1}{dτ^2}}=0##
Stella.Physics
63
So the Schwarzschild metric is given by
ds2= -(1-2M/r)dt2 + (1-2M/r)-1dr2+r22+r2sin2θ dφ2
##{\frac{d^2 x^1}{dτ^2}}=0## for Minkowski spacetime
also the geadesic equation is ##{\frac{d^2 x^a}{dτ^2}}+Γ^a_{bc}{\frac{dx^b}{dτ}}{\frac{dx^c}{dτ}}=0##
So what happens in the Schwarzschild metric and how can I find the Christoffel symbols from the Schwarzschild metric and the geodesic equations?
For slower-than-light geodesics, you can use an effective Lagrangian (which is basically the square of the one you use):
[itex]\mathcal{L} = \frac{1}{2} g_{\mu \nu} U^\mu U^\nu[/itex]
where [itex]g_{\mu \nu}[/itex] is a component of the metric tensor, and [itex]U^\mu = \frac{dx^\mu}{d\sigma}[/itex]. This is slightly easier to work with than the one you are using (although it's a little work to see that they lead to the same equations of motion). The Lagrangian equations of motion for this lagrangian are:
[itex]\frac{d}{ds} \frac{\partial \mathcal{L}}{\partial U^\mu} - \frac{\partial \mathcal{L}}{\partial x^\mu} = 0[/itex]
This gives the following form of the geodesic equation:
[itex]g_{\mu \nu} \frac{dU^\nu}{d\sigma} + [\frac{\partial g_{\mu \nu}}{\partial x^\lambda} - \frac{1}{2} \frac{\partial g_{\lambda \nu}}{\partial x^\mu}] U^\lambda U^\nu = 0[/itex]
Unfortunately, the quantity in square brackets (call it [itex]Q_{\mu \nu \lambda}[/itex]) is not exactly equal to the Christoffel symbol [itex]\Gamma_{\mu \nu \lambda} \equiv g_{\mu \alpha} \Gamma^\alpha_{\nu \lambda} = \frac{1}{2}(\frac{\partial g_{\mu\nu}}{\partial x^\lambda} + \frac{\partial g_{\mu\lambda}}{\partial x^\nu}- \frac{\partial g_{\lambda \nu}}{\partial x^\mu})[/itex]. However, if you compute [itex]Q_{\mu \nu \lambda}[/itex], then you can find [itex]\Gamma_{\mu \nu \lambda}[/itex] by symmetrizing:
[itex]\Gamma_{\mu \nu \lambda} = \frac{1}{2} [Q_{\mu \nu \lambda} + Q_{\mu \lambda \nu}][/itex]
Likes vanhees71
Related to Christoffel symbols of Schwarzschild metric with Lagrangian
1. What are Christoffel symbols and why are they important in the Schwarzschild metric with Lagrangian?
Christoffel symbols are mathematical quantities used to describe the curvature of spacetime in Einstein's theory of general relativity. In the Schwarzschild metric, they are used to calculate the geodesic equations, which represent the paths of free-falling particles in a gravitational field. The Lagrangian is a function that describes the dynamics of a system, and in the Schwarzschild metric, it is used to derive the equations of motion for particles in a gravitational field.
2. How are the Christoffel symbols calculated in the Schwarzschild metric with Lagrangian?
The Christoffel symbols for the Schwarzschild metric are calculated using the metric tensor, which describes the geometry of spacetime. The Lagrangian is then used to derive the equations of motion, which can be solved to find the Christoffel symbols.
3. What is the significance of the Christoffel symbols in the Schwarzschild metric with Lagrangian?
The Christoffel symbols are important in the Schwarzschild metric because they allow us to calculate the geodesic equations, which describe the paths of particles in a gravitational field. This is essential in understanding the effects of gravity on the motion of objects.
4. How do the Christoffel symbols change in different coordinate systems in the Schwarzschild metric with Lagrangian?
The Christoffel symbols are tensor quantities, meaning they are independent of the coordinate system chosen. However, they can be expressed differently in different coordinate systems, but they will still describe the same underlying geometry of spacetime in the Schwarzschild metric.
5. Can the Christoffel symbols of the Schwarzschild metric with Lagrangian be used to make predictions about the behavior of particles in a gravitational field?
Yes, the Christoffel symbols can be used to make predictions about the motion of particles in a gravitational field. By solving the geodesic equations, we can determine the paths of particles and make predictions about their behavior in the presence of a massive object, such as a black hole.
