Circle and a line dividing the circumference
In summary, the conversation discusses finding the equation of a circle that is divided by a given line in a 1:2 ratio. The attempt at a solution involves finding the distance of the center of the circle from the chord, making a relation between the radius and the common factor of the ratio, and using circle functions and trigonometry to calculate the radius and ultimately, the equation of the circle. However, there are discrepancies in the calculations and the final equation given may not be correct.
  • #36
SammyS said:
Let's see... How many bits are in each byte?
... and are these bits similar to crumbs - in the case of a virtual cookie ?
Speakibg of one bits in a byte...thats a good question and raises the heap of sand paradox.
Supposes i were to remove one bit from a sum of bits making a byte...would it still appear to be a byte...and if not what do we call it...then again how many bits make a byte !...very deep philosophical questions there
  • #37
SammyS said:
I would use the following for the formula of a circle, radius R and centered at point ( h, k ) :
## \displaystyle (x-h)^2 + (y-k)^2 = R^2 ##​
To get the equation in the form you want, expand the those squared terms and simplify.
For me, this form of a circle is much easier to remember. It's basically the Pythagorean theorem.
In your case:
## \displaystyle (x-5)^2 + (y-3)^2 = 10^2 ##
## x^2 - 10x +25 + y^2 -6y +9 = 100 ##​
  • #38
In your case:
Yea but 90% of the sums in our books are based on the other form of writting it.Plus we have all those T=0 rules and that whole lot of tangents ,radial axes and blah which can be best written in the other form, hence we have to remeber the General form
Exam wise its better for us...but i like the pythagoran one more...its more...clean !
Likes YoungPhysicist
  • #39
Since you have completely solved this problem, and since I had a little time to mess with Maple this weekend, here's a pdf of a Maple worksheet you might find interesting:
  • chord.pdf
Likes Navin
  • #41
One final graphic conclusion of this post:
The circle is based on the equation discussed above,not some random numbers,which means it’s “the answer”:smile:
  • #42
Cooooollllll !
  • #43
[ ATTACH=full]231144[/ATTACH]
I'm guessing you refer to post below (#40), which doesn't give a reference regarding what it is replying to.
neilparker62 said:
All good except last - need 10^2.
Checking back through posts in this tread, I had to go back to post 20, or 21 to find something this may apply to.
FYI: It helps to respond to a specific post or fragment of a post by using te "Reply" feature.
Below, @Navin makes it clear that he is replying to a thread by @LCKurtz , which by the way has a link to a pdf file which includes a very accurate graph as part of a complete solution for the problem in this thread.
Navin said:
Cooooollllll !
  • #44
Below, @Navin makes it clear that he is replying to a thread by @LCKurtz , which by the way has a link to a pdf file which includes a very accurate graphical representation of the solved problem for this thread.
Wow...this is the first time someone has analysed by words with such vigor ! +1 Navyn point to you.
You can collect +1 Navin points to get a Mega-Vyn point and subsequently go on and on to get a giga-Vyn Point.
Likes SammyS
  • #45
I did this problem completely differently. I represented the circle parametrically as
$$x=5+r\cos{\theta}$$
$$y=3+r\sin{\theta}$$
To get the intersection with the line, we can write: $$3(5+r\cos{\theta})+4(3+r\sin{\theta})=4$$or equivalently:
$$\frac{4}{5}\cos{\theta}+\frac{3}{5}\sin{\theta}=-\frac{5}{r}$$ If we let $$\cos{\phi}=-\frac{4}{5}$$and$$\sin{\phi}=-\frac{3}{5}$$we have$$\cos{(\theta-\phi)}=\cos{\psi}=\frac{5}{r}$$The values of ##\psi## that divide the circle circumference in the ratio of 2:1 are ##\pi/3## and ##2\pi-\pi/3## So, $$\frac{1}{2}=\frac{5}{r}$$or$$r=10$$
Likes YoungPhysicist, Navin and SammyS
  • #46
Noted. I think the problem was I was on page 1 of the posts and thought the last there was the last - meanwhile the discussion had moved on considerably!
  • #47
I never thought of using parametric form...then again my trigo is as week as a staircase of sand
  • #48
Yes.
I admit, that sort of thing has happened to me too .
  • #49
@Chestermiller Really elegant solution,but beyond my reach just now...:smile:though I can understand the concept behind this
