Circle equation coefficient conditions
  • Thread starter Thread starter RChristenk
    algebra-precalculus
The discussion focuses on the conditions for the coefficients in the circle equation x^2 + ax + y^2 + by = -c to define a valid circle. It is established that for the equation to represent a circle, the condition -c + (a^2 + b^2)/4 > 0 must hold, which simplifies to 4c < a^2 + b^2. The center of the circle is located at (-a/2, -b/2), and the radius is given by √((a^2 + b^2 - 4c)/4). A point of contention arises regarding a potential typo in the radius formula, where an extra 'a' appears in the term -4ac, which is argued to disrupt the symmetry of the equation. The consensus is that this discrepancy likely stems from a misunderstanding related to the discriminant of a quadratic equation.
RChristenk
Under what conditions on the coefficients ##a,b,c## does the equation ##x^2+y^2+ax+by+c=0## represent a circle? When that condition is satisfied, find the center and radius of the circle.
Basic form of circle equation
##x^2+ax+y^2+by=-c##
##\Leftrightarrow (x+\dfrac{a}{2})^2+(y+\dfrac{b}{2})^2=-c+\dfrac{a^2}{4}+\dfrac{b^2}{4}##
The conditions under which the coefficients of this equation makes a circle:
##-c+\dfrac{a^2+b^2}{4}>0##
##\Leftrightarrow 4c < a^2+b^2##
Center of circle: ##(-\dfrac{a}{2}, -\dfrac{b}{2})##
Radius of circle: ##\sqrt{\dfrac{a^2+b^2-4c}{4}} \Rightarrow \dfrac{\sqrt{a^2+b^2-4c}}{2}##
The question I have is the solution gives the radius of the circle as: ##\dfrac{\sqrt{a^2+b^2-4ac}}{2}##. Where did that extra ##a## in ##-4ac## come from?
I'd say from a typo or a reflex writing the discriminant of ##ax^2+bx+c=0## as ##b^2-4ac.##
Since the problem statement is symmetric in ##(x,a),(y,b)## there is no reason for a symmetry break in the root.
Yes I think the solution is a typo too. I can see the equation is symmetric about the origin, but what do you mean the term ##-4ac## breaks the symmetry in the root? Thanks.
If the term under the root were ##a^2+b^2-4ac## then ##a## would be distinguishable from ##b##. But the original expression ##x^2+ax+y^2+by+c=0## makes no difference between ##(x,a)## and ##(y,b)##. We could exchange the two pairs without changing anything. But if we exchange them in ##a^2+b^2-4ac## we would get ##a^2+b^2-4bc## which is not the same.
Likes SammyS and PeroK
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
