MHB Circle Equation: Solving for x^2 + y^2 + Ax + By = 0 w/y=4/3x
  • Thread starter Thread starter Monoxdifly
    Circle
The discussion revolves around finding the equation of a circle that passes through points O (0, 0) and P (6, 0), with its center on the line y = 4/3x. The equation of the circle is expressed in the standard form x^2 + y^2 + Ax + By + C = 0, leading to the conclusion that C = 0 and B = -6. By substituting the known points and applying the center's coordinates derived from the line equation, the center is determined to be at (3, 4) with a radius of 5. Ultimately, the correct equation of the circle is x^2 + y^2 - 6x - 8y = 0. The discussion highlights the importance of using geometric properties and algebraic manipulation to derive the circle's equation.
Monoxdifly
MHB
A circle L is going through the point O (0, 0) and P (6, 0). The center is in the line $$y=\frac{4}{3}x$$. The equation of the circle L is ...
A. $$x^2+y^2+6x-8y=0$$
B. $$x^2+y^2-6x-8y=0$$
C. $$x^2+y^2-8x-6y=0$$
D. $$x^2+y^2+8x+6y=0$$
E. $$x^2+y^2-4x-3y=0$$
Since the equation of a circle is $$x^2+y^2+Ax+By+C=0$$, I substituted both known points to the equation and got C = 0 as well as B = -6, so the answer is obviously B. But then my student asked "What if all options have -6 as their B? How would we know the answer?". I think it has something to do with that $$y=\frac{4}{3}x$$, but how? Please give me some hints.
Mathematics news on Phys.org
I think I would consider the standard form for a circle:
$$(x-h)^2+(y-k)^2=r^2$$
Using the given points on the circle, we then have:
$$h^2+k^2=r^2$$
$$(6-h)^2+k^2=r^2\implies 36-12h+h^2+k^2=r^2$$
Subtracting the former from the latter, we obtain
$$36-12h=0\implies h=3$$
Now, we also know:
$$k=\frac{4}{3}h\implies k=4$$
And so this then implies:
$$r^2=3^2+4^2=25$$
And so putting it all together, we have:
$$(x-3)^2+(y-4)^2=25$$
Or:
$$x^2-6x+y^2-8y=0$$
Wow, that's cool! Thank you!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
