Osvaldo
- 27
- 1
When a merry go rounds tangential velocity approach c, and horses look closer than when at rest, what is reduced, angular velocity or radius?
Massless doesn't work - that would move at the speed of light in a straight line.Osvaldo said:and I measure that 2 points in the mass-less rotating circle get closer
It doesn't work that way. The disk cannot possibly remain rigid. It must inevitably deform. As it does so the geometry of the disk changes, and the question can only be answered by analyzing the specific material involved and the resulting stresses and strains, which become infinite as the tangential velocities approach c.Osvaldo said:Obviously am not proposing this thread to discuss the resistance of the material spinning at higher speed. My point is if I am stationary and I measure that 2 points in the mass-less rotating circle get closer is it because angle I measure shrinks or because the radius of the sniping circle, measured from my stationary position is shorter?
OK so farOsvaldo said:When a merry go rounds tangential velocity approach c, and horses look closer than when at rest,
You just lost me here. My best guess is that you are trying to imagine a rigid rotating disk, though you haven't specified such a thing. As other posters have pointed out, a realistic rotating disk would break apart under the strain at tangential velocities of a few km/sec. So you are imagining somethign other than a realistic disk - but it's not clear what. A rigid rotating disk is my best guess.what is reduced, angular velocity or radius?
Are you acknowledging the question, or agreeing the premise that the horses will look closer together when the merry go round is moving? Because I don't think I agree with the premise under any interpretation of "look". As measured from the ground frame I think they'll be at least the same distance apart, and literally looked at from the ground frame they'll be uneven distances apart due to Doppler. Or am I missing something?pervect said:OK so far
I am not convinced even about that. I doubt that there is any material that would produce that result.pervect said:OK so far
The idea is that the horses are arranged on the moving platform so that an observer positioned on the rim and using the momentary tangent inertial rest frame will measure their separation as "normal" and so that an observer positioned nearby on he ground will measure their separation as "closer".Osvaldo said:and horses look closer than when at rest
If you want to know what the horses look like then you will need to account for light travel times from the different points on the merry-go-round. But if you want to know what is happening that's an easier question, and speeds close to c are not needed to conduct the experiment.Osvaldo said:When a merry go round's tangential velocity approach c, and horses look closer than when at rest...
These spots are separated by 1 km in what frame?Osvaldo said:Seems to be the merry go round was not a good example. Forget about it and the horses. Let us think what happens at he periphery of a neutron star with 2 marks at the Equator of the star and separated 1 km. In response to Dale, there are about 100 Million Neutron stars in the Milky Way that spin at high rate. One of them PSR J1748-2446ad spin at 716 RPS or 24 % c at the perihery (radius 16 km) and as far as I know has not yet disintegrated as Dale thinks might happen.
Then if a stationary observer were able to measure the distance between the spots while rotating at 0.24c, beside measuring the length contraction, my question is is there an angle contraction or neutron star radius contraction?
There is no angle contraction. There is no radius contraction.Osvaldo said:Seems to be the merry go round was not a good example. Forget about it and the horses. Let us think what happens at he periphery of a neutron star with 2 marks at the Equator of the star and separated 1 km. In response to Dale, there are about 100 Million Neutron stars in the Milky Way that spin at high rate. One of them PSR J1748-2446ad spin at 716 RPS or 24 % c at the perihery (radius 16 km) and as far as I know has not yet disintegrated as Dale thinks might happen.
This leads to a larger question of; does Einstein's equations provide for rotational accelerations in General Relativity?ibix said:the merry-go-round is rotating so a frame attached to it is non-inertial. Many of the usual rules for inertial frames do not apply.
I'm not sure what you mean. This problem (excluding the neutron star) is entirely in flat spacetime, so would be classified as a special relativity problem. No GR is needed. You can handle rotating objects fine in SR.alantheastronomer said:This leads to a larger question of; does Einstein's equations provide for rotational accelerations in General Relativity?
alantheastronomer said:does Einstein's equations provide for rotational accelerations in General Relativity?
What I'm saying is that rotations introduce a radial acceleration; since acceleration is the domain of general relativity, has this acceleration been addressed by the equations?Ibix said:I'm not sure what you mean. This problem (excluding the neutron star) is entirely in flat spacetime, so would be classified as a special relativity problem. No GR is needed. You can handle rotating objects fine in SR.
alantheastronomer said:What I'm saying is that rotations introduce a radial acceleration
alantheastronomer said:since acceleration is the domain of general relativity
alantheastronomer said:has this acceleration been addressed by the equations?
As Peter says, all scenarios in flat spacetime are in the domain of special relativity, accelerating or not. A lot of SR is taught using exclusively inertial reference frames, but there's no obligation to restrict yourself that way. If you choose a more general approach, however, you need to be aware that simple rules relating inertial frames don't work.alantheastronomer said:What I'm saying is that rotations introduce a radial acceleration; since acceleration is the domain of general relativity, has this acceleration been addressed by the equations?
The Lorentz factor at 0.24 c is about 1.03, which is hardly what I had in mind by a “tangential velocity approaching c”.Osvaldo said:One of them PSR J1748-2446ad spin at 716 RPS or 24 % c at the perihery (radius 16 km) and as far as I know has not yet disintegrated as Dale thinks might happen.
As others stated, acceleration can be treated just fine in SR, but if we want to pursue the neutron star idea, that would be GR.alantheastronomer said:since acceleration is the domain of general relativity,
Osvaldo said:Let us think what happens at he periphery of a neutron star with 2 marks at the Equator of the star and separated 1 km.
No it isn’t. ##\pi## is a defined constant and it is always about 3.14 regardless of whether your geometry is curved or flat. The ratio of the circumference to the diameter is equal to ##\pi## for flat Euclidean geometry. For other geometries the ratio changes, but it is not ##\pi##sweet springs said:It is interpreted that pi, i.e. ratio of periphery to diameter, reaches infinity
PeterDonis said:You can handle accelerations in flat spacetime just fine using SR.
I must admit, I'm confused - I thought that special relativity dealt exclusively with inertial reference frames, and that's why it's deemed "special"? The Equivalence Principle finds that acceleration due to gravity is equivalent to acceleration due to motion, doesn't it? So then the "warping" of spacetime by massive objects should also occur due to accelerations, which means that the formerly flat spacetime is no longer flat.Ibix said:As Peter says, all scenarios in flat spacetime are in the domain of special relativity, accelerating or not.
I know the Equivalence Principle holds true for linear accelerations, but I wasn't sure about accelerations that aren't along the path of motion. I thought by extension they might. I also thought that they'd be described by the off-diagonal components of the Riemann tensor. Is that correct? Could you specify which components that would be?PeterDonis said:In any solution of the EFE which is not flat spacetime, the solution tells you the acceleration of a piece of matter in any state of motion you like.
alantheastronomer said:I thought that special relativity dealt exclusively with inertial reference frames
alantheastronomer said:The Equivalence Principle finds that acceleration due to gravity is equivalent to acceleration due to motion, doesn't it?
alantheastronomer said:So then the "warping" of spacetime by massive objects should also occur due to accelerations, which means that the formerly flat spacetime is no longer flat.
alantheastronomer said:I know the Equivalence Principle holds true for linear accelerations, but I wasn't sure about accelerations that aren't along the path of motion.
alantheastronomer said:I also thought that they'd be described by the off-diagonal components of the Riemann tensor. Is that correct?
No - see, for example, the twin paradox, a classic of special relativity in which one of the twins accelerates. Special relativity deals with flat spacetime only, which is the special case referred to. It is perfectly possible to do everything in SR with only inertial frames (this does not preclude objects following non-inertial paths), and it was originally formulated that way, but you don't have to. Frames are a human invention - they don't change physics, just our description of it.alantheastronomer said:I must admit, I'm confused - I thought that special relativity dealt exclusively with inertial reference frames, and that's why it's deemed "special"?
What's acceleration due to motion and how is it different to acceleration due to gravity?alantheastronomer said:The Equivalence Principle finds that acceleration due to gravity is equivalent to acceleration due to motion, doesn't it?
This does not follow. Non-inertial frames correspond to choosing non-Euclidean slices of flat spacetime and calling them "all of space at an instant", while inertial frames correspond to using Euclidean slices, but the spacetime is flat in either case. It's like choosing to imagine slicing a block of wood (spacetime) into a stack of bowls (non-inertial frames) or a stack of plates (inertial frames). It's the same block of wood, and we're not actually slicing anything - it's just how we choose to think of dividing the block. Nothing is warped.alantheastronomer said:So then the "warping" of spacetime by massive objects should also occur due to accelerations
"Path of motion" implies a choice of frame. I can always choose a (possibly non-inertial) frame in which I am always at rest. How would you distinguish between a "linear acceleration" and an "acceleration that isn't along the path of motion" in that frame?alantheastronomer said:I know the Equivalence Principle holds true for linear accelerations, but I wasn't sure about accelerations that aren't along the path of motion.
No. The Riemann tensor describes the curvature of spacetime, and there is no such curvature in flat spacetime. In non-flat spacetime the components will depend on your choice of coordinates, but that isn't affected by whether you are undergoing proper acceleration or not.alantheastronomer said:I also thought that they'd be described by the off-diagonal components of the Riemann tensor. Is that correct?
The postulates of special relativity do specifically reference inertial frames only. However:alantheastronomer said:I thought that special relativity dealt exclusively with inertial reference frames,
Tangential velocity approaching c refers to the velocity of an object moving in a circular path, as it approaches the speed of light (c). It is the velocity component that is perpendicular to the radius of the circle at a given point.
The formula for calculating tangential velocity approaching c is v = rω, where v is the tangential velocity, r is the radius of the circle, and ω is the angular velocity (in radians per second).
Tangential velocity approaching c is important in scientific research because it is a fundamental concept in understanding the behavior of particles and their interactions at high speeds. It is also essential in fields such as relativity, astrophysics, and particle physics.
No, according to the laws of physics, tangential velocity approaching c can never reach the speed of light. As an object's velocity approaches the speed of light, its mass increases, and it requires an infinite amount of energy to accelerate it further.
As an object's tangential velocity approaches c, its trajectory becomes increasingly curved, and it will eventually move in a circular path at the speed of light. This is due to the fact that at such high velocities, the concept of linear motion breaks down and the object's path becomes more influenced by gravitational forces.
