Circuit Requirements Questions (Design of a stadium lighting system)
In summary: You must make an attempt before others can provide feedback. We are not here to do your work for you. In summary, the conversation discusses the requirements for a high integrity lighting controller for a sports stadium. The system will use a light dependent resistor (LDR) to monitor ambient light levels and switch on external lighting when necessary. Various LED indicators will be incorporated to monitor the status of the light and give warning signals if it fails. The circuit will be constructed using breadboard and circuit strip board. Some of the questions raised include the use of a thermistor to determine the status of the light, the need for resistors in series with the LEDs, and potential improvements for the circuit.
buyahyeh
[Thread moved from a technical forum, so no Homework Template is shown]
A controller is required to monitor the natural illumination of a sports stadium and, when the ambient light is below a pre-set level, to switch on external lighting. The system is required to be of high integrity, and various monitoring indicators are to be incorporated as specified below. Furthermore, the status of the light (Large white LED) is to be monitored, and if this should fail, when the lighting should in fact be on, a warning signal is to be given in the form of a flashing orange LED.The circuit brief states: 1. A light dependent resistor (LDR) is to be used to determine ambient light levels. 2. A red light emitting diode (LED) should illuminate whenever the ambient light level is below the pre-set value. 3. A green LED should be illuminated if the ambient light is above the predetermined level. Note, the use of two LEDs in this manner serves to indicate that power is applied to the system, as one LED will always be on. 4. An orange LED is to flash on and off repeatedly, in the case that the ambient light level is low, and the white LED is not illuminated, i.e., it has failed. 5. Individual functional blocks of the circuit should be constructed using breadboard, and operation verified, before soldering the relevant components to circuit strip board. One example of such a component block may be the LDR and comparator light detection circuit.
Questions
1. Provide a block diagram of the complete lighting controller, and outline the functions of the different circuit blocks. State how the different blocks interlink. A scanned hand drawn diagram is acceptable.
2. Provide a circuit diagram of the circuit that you actually produced. State the basic principles of the method of operation.
3. Theinitialsectionofthecircuitincorporatesalightdependentresistor(LDR),apotentiometer and an operational amplifier (op-amp) to detect ambient light levels. State the manner in which this part of the circuit functions.
4.A thermistor could have been used to determine when the incandescent bulb was illuminated. State if you consider this to be a reliable system to sense correct operation of the bulb.
5. By what method, other than the incorporation of an LDR, could the operational state of the bulb be determined?
6. The original circuit specified the use of a NAND gate oscillator state the operating principles of this portion of the circuit and which component you used to satisfy this function.
7. The circuit as originally designed may have incorporated a time delay function to ensure correct operation of that part of the circuit intended to indicate that the incandescent light had failed. Why would the time delay be necessary?
8. All of the light emitting diodes (LEDs) in the circuit have a resistor in series. Why are these resistors necessary?
9. Suggest a method of improving operation of circuit
:welcome:
If this is homework, or a school project, our rules say that you show us your work before we can help. So please post your thoughts on those 8 questions.
The post should also be placed in one of our homework forums.
Likes davenn
As Anorlunda says, this looks like a homework/school project
What have you done so far to work through this ?
No one here is going to do your project for you
You need to show serious amounts of effort on your part to work through the requirements of the project
Surely your study work throughout this year and previous years has taught you a lot about these various components and how they workcheers
Dave
New user has been reminded to show their work on schoolwork questions
i have done it but i want to see what others would put
So let's see what you did.
Likes Tom.G
That is NOT the way it works on this forum. Read the rules. Show your work.
FAQ: Circuit Requirements Questions (Design of a stadium lighting system)
1. What is the purpose of a stadium lighting system?
The purpose of a stadium lighting system is to provide adequate and uniform lighting for sporting events, concerts, and other activities that take place in a stadium. It also ensures the safety of players and spectators by providing proper visibility.
2. What are the key factors to consider when designing a stadium lighting system?
When designing a stadium lighting system, key factors to consider include the type of events that will take place in the stadium, the size and layout of the stadium, the required light levels for different areas, and energy efficiency.
3. How do you determine the number of circuits needed for a stadium lighting system?
The number of circuits needed for a stadium lighting system depends on the total wattage of the lights and the maximum wattage that can be handled by each circuit. This can be calculated by dividing the total wattage by the maximum wattage per circuit.
4. What type of wiring should be used for a stadium lighting system?
The type of wiring used for a stadium lighting system should be able to handle high voltage and high wattage. Generally, heavy-duty wires are used, such as copper or aluminum wiring, to ensure safety and efficiency.
5. How can the energy efficiency of a stadium lighting system be improved?
To improve the energy efficiency of a stadium lighting system, LED lights can be used instead of traditional incandescent or fluorescent lights. Additionally, using motion sensors and timers can help reduce energy consumption by turning off lights when they are not needed.
