Circuit with Diodes, Capacitors, and Resistors
In summary: V3/dt = i1 + i4dV4/dt = i2 + i3I'm not sure what you mean by comparing the polarity. From the diodes, I only know that if D1 is on (and D2 is off), V1=Vi and V2<Vi. If D2 is on (and D1 is off), V2=Vi and Vi<V1. If both are off, V2<Vi<V1. I can sub in Vi but I don't know any other V(t) input I can use in regards to the other voltages.Hint -- start with the resistor values very high (so the discharge time constant is many seconds. What
kawaiiRose
Compute V3(t)-V4(t). The capacitors are initially discharged, the voltage source is turned on at t = 0, and the diodes’ forward voltage drop is negligible (Vf = 0). What is the value of V3(10s) – V4(10s)?
Vi=4sin(2∏t)
RC= 0.1s
i (over capacitor) = CdV/dt
i (over resistor) = V/R
Assume Diode is either on (id>0) or off (id=0)
I used the node method: node above the top capacitor has voltage V1 and node above the bottom capacitor has voltage V2. Using KCL at those two nodes, I found id1=(CdV1/dt)+(V3/R) and id2=-(CdV2/dt)-(V4/R). Unknowns are id1, id2, V1, V2, V3, and V4.
Based on whether I assume a diode is on/off I can assume V1=Vi or V2=Vi and that id1=0 or id2=0, so that eliminates two unknowns. I'm still left with 4 variables though and can't see any other equations to solve for them. I was thinking use the node between the two diodes and the voltage source, but I don't know the current coming off the source. And there aren't any closed loops for me to use KVL.
Look at what the half-wave effect has - capacitors are charging for half a cycle and then discharging the other half. Compare the polarity of upper and lower caps when semi-charged.
Have you used the expression for v(t) input that results from the diodes?
I'm not too sure what you mean by comparing the polarity.
Vi=4sin(2∏t)
RC= 0.1s
Hint -- start with the resistor values very high (so the discharge time constant is many seconds. What does each capacitor charge to (that is Simon's hint)? Now, change the time constant to 0.1s -- does that change your answer by much?
The supply if giveing you a waveform of something like: vi(t)=Vsin(wt)
The sketch of this is a sign wave.
This is the wave at each diode.
The top diode means that the circuit after it will only get a particular shape v1(t) driving it.
That shape is not the same as vi(t). It is not a simple "on" vs "off" state either.
You are thinking too algebraically: look for understanding first.
What is that shape? Sketch it. Don't worry about being exact. What does the sketch look like?
Do the same for the effective driving voltage for the lower circuit - what is that?
...and thank you berkman :)
BTW, the frequency of the excitation is pretty low, so your answer may change by enough to be important
"Vi=4sin(2∏t)"
Piling on! :smile:
Related to Circuit with Diodes, Capacitors, and Resistors
1. Why are diodes used in circuits?
Diodes are used in circuits to allow current to flow in only one direction. This is important for controlling the flow of electricity and preventing damage to components.
2. What is the purpose of capacitors in a circuit?
Capacitors are used in circuits to store electrical energy and release it when needed. They are also used to filter out unwanted noise and stabilize voltage levels.
3. How do resistors affect the flow of electricity in a circuit?
Resistors limit the amount of current that can flow through a circuit. This is important for controlling the amount of electricity flowing through different components and preventing damage.
4. What is the role of a diode in a rectifier circuit?
A diode in a rectifier circuit converts alternating current (AC) into direct current (DC) by allowing current to flow in only one direction. This is important for many electronic devices that require DC power.
5. Can diodes, capacitors, and resistors be used together in a circuit?
Yes, diodes, capacitors, and resistors can be used together in a circuit to achieve different functions. For example, a circuit may use a diode and a capacitor to create a voltage doubler, or a diode and a resistor to create a voltage regulator.
