Trollfaz
- 137
- 14
Consider a circular loop with uniform current flowing around it in a uniform magnetic field.
Does it experience no translational force due to its symmetry
… and therefore, following an integral theorem and using ##\nabla \cdot \vec B = 0## (and assuming I didn't screw up the index calculus due to baby on one arm ... *),Meir Achuz said:The force would be given by ##\vec F=\oint I{\vec dr}\times \vec B=0## if I and ##{\vec B}## are constant.
Please help with LateX.
Well, yes … but that makes the generalisation to non-constant fields less obvious.Meir Achuz said:It is interesting to see these tricky ways to show that ##\oint\vec dr=\vec 0.##
Since the integral is a vector with no possible direction, it must vanish.
I meant, it's not immediately obvious, what this simple argument has to do with the original problem.vanhees71 said:That's a quick but not too obvious argument ;-)).
"Does it experience no translational force". I didn't think it was necessary to prove that the integral was zero, but two previous posts had gone to some lengths to prove what was immediately obvious.vanhees71 said:I meant, it's not immediately obvious, what this simple argument has to do with the original problem.
Well, that is a half-truth to be honest. The posts you are referring to were both treating the general case of non-constant magnetic field before specializing to the constant field scenario. This is relevant to the OP’s question in the sense of deducing the general conditions under which the total force is zero - constant field being a sufficient condition but gemerally not necessary.Meir Achuz said:"Does it experience no translational force". I didn't think it was necessary to prove that the integral was zero, but two previous posts had gone to some lengths to prove what was immediately obvious.
A circular current-carrying loop placed in a uniform magnetic field experiences a torque that tends to align the plane of the loop perpendicular to the magnetic field lines. The magnitude of this torque is given by τ = IABsinθ, where I is the current, A is the area of the loop, B is the magnetic field strength, and θ is the angle between the normal to the plane of the loop and the magnetic field.
The magnetic moment (μ) of a circular loop is defined as the product of the current (I) flowing through the loop and the area (A) of the loop. Mathematically, it is expressed as μ = I * A. The direction of the magnetic moment is perpendicular to the plane of the loop, following the right-hand rule.
The potential energy (U) of a circular loop in a uniform magnetic field is given by U = -μBcosθ, where μ is the magnetic moment of the loop, B is the magnetic field strength, and θ is the angle between the magnetic moment and the magnetic field. The potential energy is minimized when the magnetic moment is aligned with the magnetic field.
In a uniform magnetic field, a circular loop tends to rotate such that its magnetic moment aligns with the magnetic field. This is due to the torque exerted by the magnetic field on the loop. If the loop is initially misaligned, it will experience a torque that causes it to rotate until its plane is perpendicular to the magnetic field lines, minimizing its potential energy.
The right-hand rule is used to determine the direction of the magnetic moment of a circular loop. According to this rule, if you curl the fingers of your right hand in the direction of the current flowing through the loop, your thumb points in the direction of the magnetic moment. This rule helps in understanding the orientation and behavior of the loop in a magnetic field.
