Circular motion (2 particles on a string)
In summary: This is because the string is in static equilibrium, so the net force on the string (and hence the tension) must be equal to zero. Since the only forces acting on the string are the weights of the two particles, the tension in the string must be equal to the sum of these weights.
Geometor
A light inextensible string of length 0.6m has one end fixed to a point A on a smooth horizontal plane. The other end of the string is attactched to a particle B, of mass 0.4kg. A particle P of mass 0.1kg is attatched to the mid-point of the string. The line APB is straight and rotation continues at 2 rad s^-1 on the surface of the plane.
1) Calculate the tension in the section of the string AP.
2) Calculate the tension in the section of the string BP.
Centripetal force = mass x radius x (angular velocity)^2
I imagined that the tension in AP would simply be:
0.1 x 0.3 x 2^2 = 0.12N
however the answer is given as 1.08N. So my question really is how does two particles on the same string affect the tension?
I placed in q.2 for curiosity.
Thanks.
You must draw free body diagrams . You should first start with question 2 to determine the string tension BP by looking at particle B alone. Then look at particle P alone. There are 2 tension forces acting on particle P.
Excuse the poor diagram but:
A--->---<---P--->---<---B
where > and < indicates direction of the force
from left to right forces are: T1, T1, T2, T2
Considering B alone, resolving horizontally:
T(at B) = 0.4 x 0.6 x 2^2 = 0.96N
Considering P alone, resolving horizontally:
T(at P) = 0.1 x 0.3 x 2^2 = 0.12N
So I suppose this says that the resultant force on P is 0.12N.
So if we take left as positive at P,
T1 - T2 = 0.12N
T1 = 0.12 + 0.96
= 1.08N
I believe this is the correct line of thinking?
Also, if 2 particles hang on a string (light, inextensible) vertically, one above another. Will the tension in the top string be the sum of the weight of the two particles?
Thank you.
The net (resultant) horizontal force at B is 0.96N; since the only horizontal force acting at B is T1, then T1 = 0.96N
again, this is the resultant horizonatal force at P
yes
T1 - T2 = 0.12N
T1 = 0.12 + 0.96
= 1.08N
yes
yes
I would like to clarify that the tension in a string is a result of forces acting on it. In this case, we have two particles attached to the string, which means that the string is being pulled in two directions. Therefore, the tension in the string will be affected by both particles.
To calculate the tension in the section of the string AP, we need to consider the forces acting on particle P. We know that the particle is moving in a circular motion, which means there must be a centripetal force acting on it. This force is provided by the tension in the string. Using the equation for centripetal force, we can calculate the tension in the string AP as:
Tension in AP = (mass of particle P) x (radius of circular motion) x (angular velocity)^2
= (0.1 kg) x (0.3 m) x (2 rad/s)^2
= 0.12 N
Therefore, your calculation for the tension in AP is correct.
Moving on to the tension in the section of the string BP, we need to consider the forces acting on particle B. Since particle B is attached to the string, it will also experience a tension force. However, in this case, the string is not only providing a centripetal force but also supporting the weight of particle B. This means that the tension in the string BP will be equal to the weight of particle B plus the centripetal force. We can calculate this as:
Tension in BP = (mass of particle B) x (gravitational acceleration) + (mass of particle B) x (radius of circular motion) x (angular velocity)^2
= (0.4 kg) x (9.8 m/s^2) + (0.4 kg) x (0.3 m) x (2 rad/s)^2
= 0.4 N + 0.12 N = 0.52 N
Therefore, the answer given for the tension in BP (1.08 N) seems to be incorrect. Using the given values, the correct value for the tension in BP should be 0.52 N.
In conclusion, when dealing with circular motion involving multiple particles on a string, we need to consider the forces acting on each particle separately to accurately calculate the tension in the string. I hope this helps clarify any confusion.
FAQ: Circular motion (2 particles on a string)
What is circular motion?
Circular motion is a type of motion where an object moves along a circular path. This path can be either a perfect circle or an approximation of a circle. It is caused by a constant force acting perpendicular to the direction of motion, known as centripetal force.
What is the difference between uniform circular motion and non-uniform circular motion?
In uniform circular motion, the speed of the object remains constant while its direction changes. In non-uniform circular motion, the speed and direction of the object change continuously.
3. How is circular motion related to Newton's laws of motion?
Newton's first law, also known as the law of inertia, states that an object will remain at rest or in uniform motion in a straight line unless acted upon by an external force. In circular motion, this external force is the centripetal force that keeps the object moving in a circular path. Newton's second law, F=ma, can also be applied to calculate the centripetal force required for circular motion.
4. What is the role of tension in circular motion?
Tension is the force that is transmitted through a string or any other type of flexible, inelastic medium. In circular motion, the tension in the string provides the centripetal force that keeps the object moving in a circular path. Without sufficient tension, the object would fly off in a straight line.
5. How does the radius of the circular path affect the speed and acceleration of an object in circular motion?
The radius of the circular path is directly related to the speed and acceleration of an object in circular motion. As the radius increases, the speed decreases and the acceleration decreases. This is because a larger radius requires a larger centripetal force to maintain the circular motion, which is provided by a decrease in speed and acceleration.
