Circular Motion and Gravitation HELP
In summary, a new user is seeking help with a circular motion problem involving a man on a roller coaster and a bathroom scale. They are struggling to understand the concept and are looking for an explanation on how to approach the problem and why. They also ask if the problem would be solved differently if the man was at the bottom of the loop. Another user suggests using the formula for acceleration in circular motion, a = v^2/r, and then finding the force acting on the scale.
kittn44
Hey there! Completely new here but thought someone could help. I have this problem where I don't even know where to start from.
The problem:
(Picture of loop with a man in a roller coaster cart hanging upside down from furthest top point of circle)
A man in the roller coaster is sitting on a bathroom scale. If he is traveling at 33.1 m/s at the point shown, the radius of the vertical coaster track is 61 meters, and the man has a mass of 55.3 kg, to the nearest Newton, what does the scale read?
Ok, first off, the answer isn't something I'm concerned with anyway because these values will not be the same as the ones I end up having to work, so I really just need someone to explain HOW I do this and WHY. My class is only 5 weeks long and I'm taking too much in and I just don't grasp circular motion quite yet. Any ideas and help appreciated!
Also, if the man were at the most bottom point of the loop, would you work the problem differently?
THANKS :smile:
The acceleration for circular motion can be defined as:
[tex]a = \frac{v^2}{r}[/tex]
where "a" is acceleration, "v" is velocity, and "r" is the radius.
Now once the acceleration is known, how might one find the force acting on the scale?
Hi there! Don't worry, circular motion and gravitation can be a bit tricky at first, but with some practice and understanding of the concepts, you'll get the hang of it!
To solve this problem, you'll need to use the equations for circular motion and Newton's laws of motion. First, let's break down the problem into parts.
1. The man is traveling at 33.1 m/s at the point shown, which means he has a velocity in the vertical direction. This velocity is caused by the centripetal force, which is directed towards the center of the circle.
2. The radius of the vertical coaster track is 61 meters. This is the distance from the center of the circle to the point where the man is hanging upside down.
3. The man has a mass of 55.3 kg. This is important because it will help us calculate the force acting on him.
Now, to find the scale reading, we need to calculate the force that is acting on the man. This force is the sum of the weight of the man (mg) and the centripetal force (mv^2/r). We can set up an equation:
Scale reading = mg + mv^2/r
Substituting the given values, we get:
Scale reading = (55.3 kg)(9.8 m/s^2) + (55.3 kg)(33.1 m/s)^2/(61 m)
This gives us a scale reading of approximately 6,563 Newtons.
If the man were at the bottom point of the loop, the problem would be slightly different because his velocity would be different. However, the same concept applies and you would still use the same equation to find the scale reading.
I hope this helps you understand the problem better! Remember to always break it down into smaller parts and use the relevant equations to solve it. Good luck with your class! :smile:
FAQ: Circular Motion and Gravitation HELP
What is circular motion and how is it different from linear motion?
Circular motion is the movement of an object along a circular path. It is different from linear motion in that the direction of motion is constantly changing, whereas in linear motion the direction remains the same.
What is centripetal force and how does it relate to circular motion?
Centripetal force is the force that keeps an object moving in a circular path. It acts towards the center of the circle and is necessary for the object to maintain its circular motion.
What is the relationship between circular motion and gravity?
Gravity is the force that attracts objects towards each other. In circular motion, gravity plays a role in keeping the object moving in a circular path by providing the necessary centripetal force.
How does the mass and velocity of an object affect its circular motion?
The greater the mass of an object, the greater the centripetal force needed to keep it moving in a circular path. Similarly, the greater the velocity of an object, the greater the centripetal force needed to overcome its inertia and keep it moving in a circular path.
What is the difference between circular motion and uniform circular motion?
Circular motion refers to any movement along a circular path, while uniform circular motion specifically refers to circular motion at a constant speed. In uniform circular motion, the object's velocity remains constant and the centripetal force is equal to the force of gravity.
