Circular motion and gravitation
In summary, when solving for the banking angle in a banked curve problem where no dependence is placed on friction, you must use the centripetal force equation and only include forces that have a component in the direction of the centripetal acceleration. In this case, the normal force and the gravity force do not have horizontal components, so they are not included in the equation.
Inertialforce
68
Traffic is expected to move around a curve of radius 200m at 90km/h. What should be the value of the banking angle if no dependence is to be placed on friction?
ΣFc = mac
For this question what I did first was draw a top view of the situation, then I drew a side view of the same situation but with vectors to show what forces were acting on the car as it was going through the bank (free body diagram). As it turns out (since it says that no dependence is placed on friction) the only forces acting on the car along the bank are the forces Fn and Fg.
My question is when I put it into the centripetal force equation, what force do I incorporate into the equation?
For example is it:
ΣFc = mac
Fnsin(theta) = mac
or is it:
ΣFnsin(theta) + mgsin(theta) = mac
Hi Inertialforce,
ΣFc = mac
For example is it:
ΣFc = mac
Fnsin(theta) = mac
or is it:
First determine what direction the centripetal acceleration ac is in. Then, in your centripetal force equation, you find the components of all forces in that direction; those components go in the centripetal force equation. What do you get?
(That is, what is the component of the normal force in the direction ac is pointing, and the component of the gravity force in the direction ac is pointing?)
alphysicist said:
Hi Inertialforce,
In my free body diagram I have Fnsin(theta) and mgsin(theta) pointing towards the direction of my centripetal acceleration. But what I do not understand is that, I know I am supposed to write down all the forces pointing in the direction of the centripetal acceleration in my equation which would make:
ΣFc = mac
Fnsin(theta) + mgsin(theta) (because they are both pointing left to the direction of the centripetal acceleration)
However, in my physics textbook they have a example that is almost identical but in their free body diagram they only showed or expanded upon the forces of Fn (the free body diagram only includes the vectors Fn, Fncos(theta), Fnsin(theta) , and mg. I was just wondering why they do not include the cos and sin vectors for mg as well and also why they do not include mgsin(theta) or mgcos(theta) in the banked curve examples/questions that they show.
ΣFc = mac
Here is the important part: the centripetal acceleration is to the left, so it is a horizontal acceleration. But the gravity force has no component in the horizontal direction; it is a vertical force.
(What confuses many people is the similarity in the diagrams for these problems and for problems involving boxes sliding down inclined planes. But the problems are different in that for the boxes, the acceleration is down the incline, and gravity has a component parallel to the incline.
But for these banked curve problems, the acceleration is horizontal, and gravity has no horizontal component.)
FAQ: Circular motion and gravitation
What is circular motion?
Circular motion is the movement of an object along a circular path, where the distance from the center of the circle remains constant. This motion can be uniform, where the speed is constant, or non-uniform, where the speed changes at different points along the path.
What is centripetal force?
Centripetal force is the inward force that keeps an object moving in a circular path. It is directed towards the center of the circle and is necessary for an object to maintain its circular motion. This force can be provided by tension, gravity, or any other force that acts towards the center.
How is centripetal force related to circular motion?
Centripetal force is necessary for an object to maintain its circular motion. Without this force, the object would continue moving in a straight line, as dictated by Newton's first law of motion. The magnitude of centripetal force is directly proportional to the mass of the object and the square of its velocity, and inversely proportional to the radius of the circular path.
What is the difference between centripetal force and centrifugal force?
Centripetal force is the inward force that keeps an object moving in a circular path, while centrifugal force is the apparent outward force experienced by an object in circular motion. Centrifugal force is not a real force, but rather an apparent force that arises due to the object's inertia, which tends to keep it moving in a straight line.
How is circular motion related to gravitation?
Gravitation is the force of attraction between two objects due to their masses. In circular motion, the centripetal force that keeps an object moving in a circular path can be provided by the gravitational force between the two objects. This is seen in the case of the Earth orbiting around the Sun, where the gravitational force between the two objects acts as the centripetal force, keeping the Earth in its orbit.
