Circular Motion and the Law of Gravitation -- question
In summary, Matt Damon is stuck on Mars and needs to determine his take-off speed to make it into orbit and rendezvous with the rescue team. He throws a ball and measures the acceleration due to gravity on Mars in terms of the initial speed, distance, and angle. Using Kepler's third law and the fact that the gravitational force must be a centripetal force, he determines the radius of orbit of Phobos. Finally, using the orbital speed of the rescue team and his own launch conditions, he calculates the speed with which he must launch his rocket to reach the proper orbit. However, the given solution may be incorrect due to the assumption of a small orbital altitude.
John Kim
Matt Damon is stuck on Mars. He needs to get o the planet and into orbit to rendezvous with the rescue team, which will be orbiting the planet at the same radius as Phobos, one of Mars’s moons. His goal is to determine what his take-of speed should be so that he makes it into orbit. Assume circular orbits throughout this problem. (i) First, Matt Damon throws a ball with an initial speed of v0 at an angle theta above the horizontal and measures that the ball lands a horizontal distance d away from where he threw it. Ignoring his height, determine the acceleration due to gravity on Mars, g, in terms of v0, d, and theta.
(ii) Next, he measures the period, T, of Phobos’s orbit as well as the radius of Mars, R (he does the latter using a method similar to that of Eratosthenes). Given this information and your result for g above, determine the radius r of orbit of Phobos, in terms of T,R,d, v0, and theta (and any constants). Hint: Think about Kepler’s third law. Use that the gravitational force must be a centripetal force.
(iii) Lastly, he recalls from his astronaut training that the orbital speed of the rescue team will be vf , and hence he needs to end up orbiting at radius r with speed vf . Determine the speed, v, with which he must launch his rocket to make it to the proper orbit (you may neglect Mars’s rotational motion). Your answer should be in terms of vf,d, v0, theta, T, and R.
F=gm1m2/r^2
a = v^2/r
T=2piR/v
https://imgur.com/a/f8Bv2
(here is the attempt from Chegg) however, i am not sure how we got part iii) when solving for the velocity he must launch the rocket. Really clueless on how he got v = sqrt(Vf^2 + 2gr) for the components of velocity
You mean, how they got that for the launch speed, right? The components would be Vf horizontal and 2gr vertical (though if r is being measured from the centre of Mars, shouldn't that be 2g(r-R)? It says r is the radius of the orbit, not the altitude.)
Can you see how they get those components?
That said, that result is only valid if the orbital altitude is small compared with R, which is not what the diagram suggests. Looks to me like an incorrect solution.
Related to Circular Motion and the Law of Gravitation -- question
1. What is circular motion?
Circular motion is the movement of an object along a circular path, where the object's distance from a fixed point remains constant. This type of motion can be observed in many natural phenomena, such as the orbit of planets around the sun.
2. What is the law of gravitation?
The law of gravitation, also known as Newton's law of universal gravitation, states that every object in the universe attracts every other object with a force that is directly proportional to the product of their masses and inversely proportional to the square of the distance between them.
3. How does circular motion relate to the law of gravitation?
Circular motion is a result of the gravitational force between two objects. In circular motion, the centripetal force (the force that keeps an object moving in a circular path) is provided by the gravitational force between the objects. The strength of this force depends on the masses of the objects and the distance between them, as described by the law of gravitation.
4. What is the difference between circular motion and elliptical motion?
Circular motion is when an object moves in a perfect circle, while elliptical motion is when an object moves in an oval or elliptical path. In circular motion, the distance from the object to the fixed point remains constant, whereas in elliptical motion, the distance changes as the object moves closer and farther away from the fixed point.
5. How is circular motion and the law of gravitation used in real life?
Circular motion and the law of gravitation are used in many real-life applications, such as satellite orbits, the motion of planets around the sun, and the motion of electrons around an atomic nucleus. They also play a crucial role in understanding the forces that keep objects in orbit and predicting the movement of celestial bodies in our solar system.
