Circular Motion angle b/w acc and velocity etc.
In summary: Thanks andIn summary, the angle between the velocity vector and the acceleration vector is 90 degrees.
Sagar98
How do you find the angle b/w tangential acceleration and total acceleration vector, Or angle between velocity vector and Acceleration vector. I'm really confused about this and no one's helping.
Hi sagar98,
I am a bit confused about what you are asking as your question, as put at the moment can lead to multiple interpretations. For a quick answer please try to be more precise.
So you have a circular motion of an object. I assume constant velocity. For this to happen the centripetal force (http://en.wikipedia.org/wiki/Centripetal) needs to act from the body towards the center of the rotation curve to keep the rotation going in a circle. Example a rock spinning around a pole held by a string from the pole to the rock. Here the force is the tension in the string and is orthogonal to the velocity vector, pointing towards the pole.
The centrifugal force is a fictitious force (as it is basically inertia) and completely opposes the centrifugal. It is felt by the rock. The two forces cancel each other and the rock has no acceleration and keeps a constant velocity in it's circular motion.
The angles are always 90 deg' from the velocity vector. Centripetal towards the pole, centrifugal opposite.
Have fun!
Thanks and What if it's undergoing uniform tangential acceleration? Then how does the angle vary?
I think what you are after is the resultant between the Constant Tangential Acceleration (at) and the centripetal acceleration v2/r. At time t (from rest, perhaps?), you can calculate the value of v so you will then have both acceleration vectors and can show their vector sum in Mag and Direction relative to radius (or whatever).
In order to simplify the whole setup you could change your fixed frame of reference to the object to be accelerated with the Y axis pointing to the center of rotation. While the rest of the world spins accelerated around the center of rotation. This will eliminate the varying angle of position from your calculation.
Thus you will get your acceleration on the X axis and the centripetal on the Y. You just need to express the centripetal variance according to Time and the tangential acceleration. And the rest is simple trigonometry.
FAQ: Circular Motion angle b/w acc and velocity etc.
What is circular motion?
Circular motion is a type of motion in which an object moves along a circular path. This path can be either a perfect circle or an arc. In circular motion, the object's speed or velocity remains constant, but its direction changes continuously.
What is the relationship between acceleration and velocity in circular motion?
In circular motion, the direction of the velocity vector is always tangent to the circular path, while the acceleration vector points towards the center of the circle. This means that the acceleration and velocity vectors are perpendicular to each other, and their magnitudes are related by the equation a = v^2/r, where a is the acceleration, v is the velocity, and r is the radius of the circle.
How is the angle between acceleration and velocity calculated in circular motion?
The angle between acceleration and velocity in circular motion can be calculated using the equation θ = tan^-1(a/v^2), where θ is the angle, a is the acceleration, and v is the velocity. This angle is constantly changing as the object moves along the circular path.
What is centripetal force in circular motion?
Centripetal force is the force that keeps an object moving along a circular path. In circular motion, this force is directed towards the center of the circle and is responsible for continuously changing the direction of the object's velocity. It is calculated using the equation F = mv^2/r, where F is the centripetal force, m is the mass of the object, v is the velocity, and r is the radius of the circle.
How does the radius of the circle affect circular motion?
The radius of the circle has a direct impact on circular motion. As the radius decreases, the centripetal force and acceleration increase, causing the object to move faster. On the other hand, a larger radius results in a smaller centripetal force and acceleration, leading to a slower movement. Additionally, the radius also affects the angle between acceleration and velocity, with a larger radius resulting in a smaller angle and vice versa.
