Circular motion, coin on a rotating disk
The discussion focuses on calculating the linear velocity of a coin on a rotating disk at 61 revolutions per minute, resulting in a linear speed of 1.662 m/s. The user attempts to determine the maximum radius for the coin's stability using the equation mu(v^2/r)=g, but questions arise regarding the accuracy of this formula. Clarifications are made regarding the calculation of the period of revolution and whether the radius used corresponds to the edge of the platform. The conversation highlights the importance of verifying equations and ensuring correct parameters in physics calculations. Overall, the thread emphasizes the need for accurate application of formulas in circular motion problems.
fallingforfandoms
A small button placed on a horizontal rotating platform with diameter 0.520 m will revolve with the platform when it is brought up to a speed of 41.0 rev/min , provided the button is no more than 0.250 m from the axis.
How far from the axis can the button be placed, without slipping, if the platform rotates at 61.0 rev/min ?
In the previous part of the question we found mu = 0.47
mu(v^2/r)=g
First I tried to convert V = 61 rev/min to linear velocity.
frequency = 61 rev / 60 sec = 1.017 rev/sec
time = 1/f = 0.983 s
V = 2(pi)r/t = 0.52*pi/0.983= 1.662 m/s
From there I tried to find the maximum radius the coin could be at by using mu(v^2/r)=g
r = mu(v^2)/g
r= 0.47(2.76)/9.8
r= 0.13 m
That seems to be wrong though, so now I am a bit lost.
Where did you get this equation? Check your source.
Welcome to Physics Forums!
Relevant Equations:
mu(v^2/r)=g
This formula as written is not correct. Check it.
OK. (The time here is the period of revolution of the platform when it is rotating at 61 rpm.)
Did you let r equal the radius of the platform in this calculation? If so, wouldn't V then equal the linear speed of a point at the outer edge of the platform? Is that the speed that you want?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
