Circular motion grade 12 physics
In summary, the conversation discusses a problem involving keys attached to a string and swung in a circular path. The first part of the question asks for the minimum velocity required to maintain the circular path, and the second part asks for the tension in the string at the bottom of the circle. The solution involves using the equation Fc=mv^2/r and conservation of energy. The conversation also mentions using calculus, but it is not necessary to solve the problem.
Specter
120
Keys with a combined mass of 0.100 kg are attached to a 0.25 m long string and swung in a circle in the verical plane.
a) What is the slowest speed that the keys can swing and still maintain a circular path?
b) What is the tension in the string at the bottom of the circle?
Fc=mv2 /r
I haven't learned about conservation of energy yet but it looks like I will need it to solve this problem. I'm stuck on part b but I will post my answer to part a and b.
A) When they keys are at the top of their path the only force that is acting on them is gravity.
Fc=Fg=mg
Fc=mv2 /r
g=v2 /r
v2 =√(9.8m/s)(0.25 m)
v= 1.565 m/s
Therefore the minimum velocity that is required to keep the keys swinging in a circular path is 1.565 m/s.
Part b.
I have only learned about uniform circular motion. If gravity accelerates the keys on the way down and slows them on the way up, wouldn't that mean this question is not uniform circular motion? I tried my best to solve it but I haven't actually learned any of this yet so it will probably have mistakes.
My first attempt is solving it as uniform circular motion because that's what I learned in the lesson:
Fc= mv2 /r
Ft-Fg = mv2 /r
Ft-mg= mv2 /r
Ft= mv2 /r +mg
Ft= (0.100kg)(1.6m/s)2 /0.25m +(0.100kg)(9.8m/s2)
Ft=2.0 N
I don't think this is right because the velocity at the top and bottom would be different but the only way to find the velocity at the bottom would be to use conservation of energy which I haven't learned yet...
Attempt 2 assuming it isn't uniform circular motion:
The top of the circle will be 0.50m and the bottom will be 0m.
Top of the circle
Eg=mgh
=(0.100)(9.82)(0.50)
=0.49 J
Bottom of the circle
Eg=mgh
=(0.100)(9.82)(0)
=0 J
0.49 is the GPE at the top of the circle.
I can calculate the kinetic energy to find the potential energy at the bottom
Ek=1/2 mv2
=1/2 (0.100)(1.565)2
=0.12 J
Etotal = Eg+Ek
=0.49 J + 0.12 J
= 0.61 J
The bottom of the circle is set to 0 therefore the GPE at the bottom will equal 0 and the kinetic energy at the bottom will equal 0.61 J.
Use kinetic energy to find velocity
Ek= 1/2 mv2
v2=√2(0.61)/0.100
v=3.49 m/s
Now using velocity to find the tension in the string
Fc=Ft-Fg
Ft-Fg=mv2 /r
Ft=mv2 /r +mg
Ft=(0.100)(3.49)2 /0.25 +(0.100)(9.82)
Therefore the tension in the string at the bottom of the circle is 5.85 N.
Are you allowed to iuse calculus to solve part b?
Nope. I am taking a calculus course also, but I think they want me to use what I learned in the lesson and nothing else. How would I use calculus to solve this problem?
Conservation of energy is by far the easiest way to determine the velocity at the bottom of the path. Do you know about gravitational potential energy?
Likes Specter
I very briefly read about gravitational potential energy but I haven't learned about it in the lesson where this question came from. I used GPE=mgh to find the gravitational energy at the top and the bottom of the circle in my second attempt.
Related to Circular motion grade 12 physics
1. What is circular motion?
Circular motion is the movement of an object along a circular path, where the object travels at a constant speed but changes direction continuously.
2. What causes circular motion?
Circular motion is caused by a force, such as gravity or tension, acting on an object and constantly changing its direction towards the center of the circular path.
3. How is the speed of an object in circular motion calculated?
The speed of an object in circular motion can be calculated using the formula v = 2πr/T, where v is the speed, r is the radius of the circular path, and T is the time it takes for the object to complete one full rotation.
4. What is centripetal force?
Centripetal force is the force that acts on an object in circular motion, pulling it towards the center of the circular path. It is necessary to keep the object moving along the circular path.
5. How does the radius of the circular path affect the speed of an object in circular motion?
The speed of an object in circular motion is inversely proportional to the radius of the circular path. This means that as the radius increases, the speed decreases, and vice versa.
18K
