Circular motion of a bucket filled with water
In summary, when a bucket filled with water is in vertical circular motion, there exists a contact force between the water and the bucket at the top of the center of rotation. This is because the bucket is accelerating downwards at more than 1g, providing a centripetal force to constrain the water to move in a circular path. If the bottom part of the bucket is removed while at the top, the water will leave through the bottom and travel on a tangential path, as if any mass were being swung on a string in a vertical plane. The contact force will be at least twice the weight of the water if the rotation is uniform. When doing a force balance on the water in the bucket, the equation R+mg=mv
  • #36
Yes Thank you for modelling my query as a formal physics question.
<h2>1. What is circular motion?</h2><p>Circular motion is the movement of an object along a circular path. It involves a continuous change in direction, but the speed of the object remains constant.</p><h2>2. How does a bucket filled with water move in circular motion?</h2><p>A bucket filled with water will move in circular motion if it is swung around in a circular path. The water inside the bucket will also move in a circular path due to the centrifugal force created by the rotation.</p><h2>3. What is the role of centrifugal force in circular motion of a bucket filled with water?</h2><p>Centrifugal force is the outward force that acts on an object moving in a circular path. In the case of a bucket filled with water, the centrifugal force is responsible for keeping the water in the bucket as it moves in a circular motion.</p><h2>4. How does the speed of the bucket affect the circular motion of the water inside?</h2><p>The speed of the bucket affects the circular motion of the water inside in two ways. Firstly, a higher speed will create a stronger centrifugal force, causing the water to move in a wider circular path. Secondly, a higher speed will also cause the water to rise up the sides of the bucket due to the inertia of the water.</p><h2>5. What happens to the water inside the bucket when the circular motion stops?</h2><p>When the circular motion stops, the centrifugal force acting on the water also stops. This causes the water to move in a straight line, resulting in the water spilling out of the bucket. The water will continue to move in a straight line until it is affected by another force, such as gravity.</p>
Related to Circular motion of a bucket filled with water
11K
