Circular Motion of a car around a curve
In summary, the problem discusses a car rounding a banked curve with a given radius of curvature, banking angle, and coefficient of static friction. The task is to determine the range of speeds the car can have without slipping up or down the road. The solution involves drawing free-body diagrams and using Newton's 2nd law to find the horizontal and vertical components of the forces acting on the car. The net force in the vertical direction is equal to 0, while the net force in the horizontal direction is equal to Nsinθ+fcosθ. The sum of the horizontal components of each force is equal to the centripetal force, which can ultimately be used to find the maximum speed of the car without slipping.
haha1234
109
A car rounds a banked curve as discussed in Example 6.4 and shown in Figure 6.5.The radius of curvature of the road is R,the banking angle is θ,and the coefficient of static friction is μs.
Determine the range of speeds the car can have without slipping up or down the road.
I've just drawn two free-body diagram representing the situation that the centripetal acceleration is large that the car tends to sliding up and the opposite situation.
But I don't know how to find the range.
Good.
Apply Newton's 2nd law to each extreme. That will allow you to solve for the speeds.
What forces are there?
Observe that the net force on the car must be strictly horizontal.
Doc Al said:
Good.
Is the friction accounts for the centripetal acceleration?
What accounts for the centripetal acceleration is the net force on the car. That includes the friction.
There is my attempted solution:
tanθ=F/mg
F=mgtanθ
mgtanθ+fcosθ=mvmax2/R
gtanθ+μsg=vmax2/R
vmax=[Rg(tanθ+μs)]1/2
But it's not the correct answer.
Could you tell me the mistakes?
tanθ=F/mg
F=mgtanθ
What is F?
Do this: List all forces acting on the car. There are three. Then write Newton's 2nd law for vertical and horizontal components.
Doc Al said:
What is F?
Like this?
Where is the force of friction?
ehild
haha1234 said:
Like this?
In your diagram, I'd like to see three vectors only--representing the three forces acting on the car.
Then I'd like you to list the horizontal and vertical components of each force. You'll use those components to write Newton's 2nd law.
How to find the horizontal component of the weight?
I think Wb in the picture is not parallel to the centripetal acceleration,so it may not be a component of the centripetal force.
W is vertical, it does not have horizontal component. ehild
So is the weight giving the centripetal acceleration?
Why do you think so?
ehild
As ehild explained, since the weight acts vertically, the horizontal component will be zero.
For some reason, you found components of the weight parallel (Wb) and perpendiculur (Wa) to the incline surface. This was not necessary--stick to horizontal and vertical components.
(FYI: If you took the horizontal components of both Wa and Wb, you'll find that they cancel out.)
Doc Al said:
As ehild explained, since the weight acts vertically, the horizontal component will be zero.For some reason, you found components of the weight parallel (Wb) and perpendiculur (Wa) to the incline surface. This was not necessary--stick to horizontal and vertical components.
Finally I've found that the vmax=[Rg(tanθ+μs)]
But the right answer is [Rg(tanθ+μs)/(1-μstanθ)].
How (1-μstanθ) comes out?
You still have not clearly explained your working.
If N is the normal force and F the frictional force, what is the net force in the vertical direction, and what is the net force in the horizontal direction? (You can take F as being either up slope or down slope as you wish, so long as you are consistent.)
Is the net force in vertical direction 0N?
Is the net force in horizontal direction Nsinθ+fcosθ?
Again, don't just give answers, show your work step by step. Once again I request that you give the vertical and horizontal components of each force.
Yes, the net force in the vertical direction will equal 0, but express this as an equation: ∑Fy = 0. What is ∑Fy?
Yes, for one of the extremes.
Doc Al said:
Yes, the net force in the vertical direction will equal 0, but express this as an equation: ∑Fy = 0. What is ∑Fy?Yes, for one of the extremes.
Ny+W=0?
And I would like to know whether the sum of the the horizontal component of each force is the centripetal force.
haha1234 said:
Ny+W=0?
There are three forces. Please list the horizontal and vertical components of each. Pay attention to sign.
That happens to be true, but the better way to understand it is to think of the acceleration and then apply Newton's 2nd law. In this case the acceleration is centripetal and it acts horizontally.
Vertical component:
Ny-W-fsin=0?
Horizontal component:
Nx+fcosθ=mv2/R?
haha1234 said:
Vertical component:
Ny-W-fsin=0?
Express Ny in terms of θ and N.
Nx+fcosθ=mv2/R?
Same comment: Express Nx in terms of θ and N.
But you are getting closer! Also: Express the friction in terms of the normal force.
Nx+fcosθ=mvmax2/R
mgtanθ+μsNcosθ=mvmax2/R
gtanθ+μs(g/cosθ)cosθ=vmax2/R
But it's not the correct answer.:cry:
haha1234 said:
Nx+fcosθ=mvmax2/R
mgtanθsNcosθ=mvmax2/R
Why do you think Nx = mgtanθ?
Just call the normal force N; it is one of the unknowns. Do as I suggested: Express Nx and Ny in terms of N and θ. (Don't solve for N in terms of anything else. That comes later.)
Nsinθ+μsNcosθ=mvmax2/R
N(sinθ+μscosθ)=mvmax2/R
vmax=[RN(sinθ+μscosθ)/m]1/2?
But why Nx not equals to mgtanθ?
I think Ny=mg,so Nx=mgtanθ.
Good! That equation comes from applying Newton's 2nd law in the horizontal direction. Now get a second equation by applying Newton's 2nd law in the vertical direction.
Well, you are wrong. Don't guess! Write the equations and solve for the unknowns. (The only one you need to solve for is the velocity.)
Likes 1 person
Thank you!
I can find the correct answer now!
  • #31
Good!
Related to Circular Motion of a car around a curve
1. What is circular motion?
Circular motion is the movement of an object along a circular path, where the object's distance from a fixed point remains constant while its direction constantly changes.
2. How does a car move in a circular motion around a curve?
A car moves in a circular motion around a curve by constantly changing its direction while maintaining a constant speed. This is possible because of the car's centripetal force, which is directed towards the center of the circular path.
3. What factors affect the circular motion of a car around a curve?
The factors that affect the circular motion of a car around a curve include the car's speed, mass, and the radius of the curve. The greater the speed and mass of the car, the more centripetal force is required to maintain the circular motion. The smaller the radius of the curve, the greater the centripetal force needed.
4. How does the centripetal force affect a car's motion around a curve?
The centripetal force is responsible for keeping the car moving in a circular path around the curve. It acts as a "pull" towards the center of the curve, counteracting the car's tendency to continue moving in a straight line. Without centripetal force, the car would move in a straight line instead of a circular path.
5. How can we calculate the centripetal force of a car moving around a curve?
The centripetal force can be calculated using the formula F = mv²/r, where F is the centripetal force, m is the mass of the car, v is the velocity, and r is the radius of the curve. This formula shows that the centripetal force is directly proportional to the mass and velocity of the car, and inversely proportional to the radius of the curve.
