Circular Motion of a Ferris wheel
The discussion revolves around calculating the centripetal acceleration and effective weight of a person on a Ferris wheel with a radius of 16m, rotating every 20 seconds. The correct formula for centripetal acceleration is a = ω² * r, where ω must be accurately calculated. At the highest point, the effective weight is the sum of gravitational force and centripetal force, while at the lowest point, it is the difference. The calculations provided indicate that the person feels heavier at the bottom and lighter at the top due to the direction of forces acting on them. Proper application of Newton's second law and free body diagrams is essential for accurate results.
2Big2Bite
An Ferris Wheel has a radius of 16m and rotates once every 20 seconds.
a) Find Centripedal acceleration.
b) Whats the effektive wheight of a 45 kg person at highest point?
c) Lowest point?
a) I tried using the a=ω2*r in a) but not sure if its right
b)
c) We = mg - ma
Is this the correct equation for a and b?
I got out 1,578m*s-2 in a) but not sure if that's correct really.
and also strugling with b) and c)
But here's c) atleast trying using that equation:
45kg*9,82m*s-2 - 45kg*1,578m*s-2= 370,89N Is that right?
and b) do i use same equation for upward motion?
for a you should end up with an acceleration, not a velocity
a=ω^2*r works but you need the correct value of omega, what did you use?
b and c are just adding up the forces acting at those points. Just make sure you have a good understanding of which direction the centripetal force is directed.
Oh yeah it was -2 not -1. Spelling error.
I Used for omega, ω = \frac{(2π*3)}{60}
The motions are up and down verticaly, but not sure if that formula is right or if i need to add other things to it
well, basically the centripetal force is always pointing towards the center of the circle, and the force due to gravity is always pointed downwards.
So at the top, they are pointed in the same direction, at the bottom they are pointed in opposite directions. So how would you find the net force acting on someone at the top and then at the bottom?
Well when going upward you add weight since your pushed "into the seat", and down you take weight when the seat accelerate away from you.
So it would be F = mg+ma at the top since its "added weight"
45kg*9,82m/s^2+45*1,578m/s^2= 512,91N
And when you go down it will be the same but with (-):
45kg*9,82m/s^2-45*1,578m/s^2 = 370,89NOr is this as wrong as I can get? I'm new to this things so I might not be so good at it.
yeah that looks correct
Okey thanks for the help!
This is not correct. The person's effective or 'apparent' weight is the magnitude of the normal force of the seat that pushes up on him or her. The person feels lighter at the top than at the bottom. Use good free body diagrams and Newton's 2nd law to find the normal force at the top, and then at the bottom.
  • · Replies 18 ·
