Circular Motion - Orbital Mechanics
In summary, the orbital velocity of two objects in the same orbit around a planet is the same regardless of their mass. This is because the acceleration due to centripetal force is equal for both objects, and the mass cancels out in the equation for centripetal force. This is similar to the independence of mass in objects falling near Earth's surface, where the increased force due to gravity is canceled out by the increased inertia of the object.
Jimmy87
686
Question 1. If two objects were in the same orbit around a planet they would both have the same orbital velocity regardless of their mass. Using the equation given, explain why an object with twice the mass experiences the same orbital velocity.
Centripetal force = mv^2/r
I know it has something to do with gravitational forces being proportional to mass but I am unsure how to relate it to the equation. If the object was twice as massive then it would experience twice the centripetal force which I thought would tend to increase the velocity?
I have seen other sources say things about planets/objects in orbit 'fall' like objects on Earth but wouldn't the velocity related to falling objects on Earth be different to the velocity of objects in orbit as their velocity is tangential which isn't influenced by gravity?
Any help is much appreciated! :)
hint: If their orbits are identical, the acceleration due to the centripetal forces must be identical. Use that.
Likes 1 person
Thanks for your reply. So if your saying the acceleration is constant then v^2/r must be constant. Since r is constant then v^2 is also constant and hence v is constant? Is that right? What equation shows that acceleration is constant if the orbits are the same? How does all this relate to the independence if mass though?
To be in the same orbit means that v and r are the same.
Newton's 2nd law. What force holds an object in orbit?
Likes 1 person
Sorry. I think I may have underestimated what is expected. If "identical orbits" means identical paths and velocities, then the conclusion is true by definition. If "identical orbits" means identical paths, even if velocities are different, then it is not so simple. So my initial statement, "If their orbits are identical, the acceleration due to the centripetal forces must be identical." is really assuming what you are asked to prove.
Here is what I had in mind. Acceleration due to centripetal force is not constant, just independent of mass. Two masses, m1 and m1 with identical accelerations gives f1/m1 = a1 = a2 = f2/m2. Substitute your equation for centripetal forces, f1 and f2, and the mass cancels out, giving v1 = v2.
Likes 1 person
Yeah, I misread the question. By identical orbits they just mean the same radius. It's up to you to prove that the velocities must be the same, regardless of mass.
My previous 'tip' still holds: Go back to Newton's 2nd law. Solve for the velocity and see if it depends on the mass of the object.
Likes 1 person
Thanks for the replies guys but I'm a bit confused now. Does being in the same orbit mean v and r are the same as the last two posts seem to contradict each other? Can you be in the same orbit with a different velocity?
Sorry Doc Al I didn't see your latest thread as my page id not refresh please ignore my last post
That's for you to figure out. For a given orbital radius, can you find the velocity? What does it depend on?
The equation for orbital velocity is the square root of GM/R
Is it suffice just to say that since R (same orbit), M (both orbiting same mass) and G are all the same then v must be the same by definition? Is that correct?
I am still unsure how to explain the fact that doubling the mass keeps the velocity to the same other than to state the obvious and say that it is missing in the equation and therefore must be independent.
I understand that doubling the mass of an object near the Earth's surface doubles the gravitational force but also doubles the inertia which results in the same acceleration (g) and hence mass independence. Not sure how to connect this to an orbital problem though?
Good.
Yes, but I wouldn't say 'by definition'. Assuming you can prove the expression for orbital velocity from first principles. Do that!
It's the same reason that a falling object has the same acceleration regardless of mass. If you double the mass you double the force (gravity), which just cancels out (Newton's 2nd law) to give you the same acceleration.
Likes 1 person
Doc Al said:
Good.
Thanks for your help Doc Al! So if we know that from sqrt of GM/R means that v is the same for the same orbit (i.e. same R). Is it ok for me to use this and go on to say that this must mean that v^2/r must also be the same which means the centripetal acceleration must be the same? Then to finish off with the whole mass independence thing can I say that doubling the mass would tend to double the centripetal acceleration (which would then increase v) but since the inertia doubles the centripetal acceleration and thus the velocity remains constant. Is that logical?
Sure.
Sounds good to me.
Likes 1 person
FAQ: Circular Motion - Orbital Mechanics
What is circular motion and how does it relate to orbital mechanics?
Circular motion is the movement of an object along a circular path. In orbital mechanics, this refers to the motion of a celestial body, such as a planet or moon, around another body due to the force of gravity.
What are the key factors that affect circular motion in orbital mechanics?
The key factors that affect circular motion in orbital mechanics are the mass of the objects involved, the distance between them, and the gravitational force between them. Other factors such as the shape and inclination of the orbit also play a role.
How is circular motion different from elliptical motion in orbital mechanics?
Circular motion is a type of elliptical motion with a constant distance between the two objects involved. In contrast, elliptical motion has varying distances between the objects, resulting in a more oval-shaped orbit.
What is the significance of orbital velocity in circular motion?
Orbital velocity is the speed at which an object must travel to maintain a circular orbit around another body. It is dependent on the mass of the objects and the distance between them. If the orbital velocity is too slow, the object will fall towards the larger body. If it is too fast, the object will escape the orbit.
How does circular motion in orbital mechanics impact our understanding of the universe?
Studying circular motion in orbital mechanics has allowed us to develop a better understanding of how celestial bodies interact and move in space. It has also helped us make predictions about the future movements of these bodies and has been crucial in the development of space exploration and satellite technology.
