Circular Motion: Plane does a loop
In summary, the problem involves finding the minimum radius of a vertical loop performed by a jet pilot, given a speed of 700km/hr at the bottom of the loop and a maximum acceleration of 6.0g's. The relevant equation is Fcentripetal = MV^2/R, and the desired result can be obtained by setting the centripetal acceleration equal to 6 times the acceleration due to gravity on earth.
thussain93
A Jet pilot takes his aircraft in a vertical loop. if the jet is moving at a speed of 700km/hr at the bottom of the loop, determine the minimum radius of the loop if the acceleration at the lowest point doesn't exceed 6.0g's (this means 6.0 x acceleration due to gravity on earth)
Fcentripital = MV^2/R
All i know is that 700km/hr is 194.44m/s
and i also know that the Fg at the bottom would be -58.8N
I'm totally stuck, help me out thanks
Welcome to PF!
Hi thussain93! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
It just means find R such that the centripetal acceleration is 6 times 9.8. :smile:
I would approach this problem by first understanding the concept of circular motion. When an object moves in a circular path, it experiences a centripetal force directed towards the center of the circle. This force is given by the equation Fcentripetal = MV^2/R, where M is the mass of the object, V is its velocity, and R is the radius of the circle.
In this case, the jet pilot is experiencing a centripetal force at the bottom of the loop, which is equal to the sum of two forces: the force of gravity (Fg) and the normal force (Fn) from the wings of the jet. Since the acceleration at the lowest point of the loop is limited to 6.0g's, we can set the centripetal force equal to 6 times the force of gravity, or 6Fg.
Using the given speed of 700km/hr (194.44m/s) and the equation Fcentripetal = MV^2/R, we can set up the following equation:
6Fg = M(194.44m/s)^2/R
We also know that Fg = Mg, where g is the acceleration due to gravity on Earth (9.8m/s^2). Substituting this into our equation, we get:
6Mg = M(194.44m/s)^2/R
Solving for R, we get:
R = (M(194.44m/s)^2)/(6Mg)
R = 588.23m
Therefore, the minimum radius of the loop is 588.23m. This means that the jet pilot must maintain a circular path with a radius of at least 588.23m in order to not exceed 6.0g's of acceleration at the bottom of the loop.
FAQ: Circular Motion: Plane does a loop
What is circular motion?
Circular motion is a type of motion in which an object moves along a circular path at a constant speed.
How does a plane do a loop in circular motion?
In order for a plane to do a loop in circular motion, it must maintain a constant speed and tilt its wings at a specific angle to create enough lift to overcome the force of gravity.
What is the centripetal force in circular motion?
The centripetal force is the force that pulls an object towards the center of a circular path, keeping it in circular motion. In the case of a plane doing a loop, the centripetal force is provided by the lift generated by the tilted wings.
What factors affect circular motion?
The speed of the object, the radius of the circular path, and the mass of the object are all factors that affect circular motion. In the case of a plane doing a loop, the angle of the wings and the force of gravity also play a role.
How is circular motion related to Newton's laws of motion?
Circular motion is related to Newton's laws of motion in that it demonstrates the first law, also known as the law of inertia, which states that an object will remain in its state of motion (in this case, the circular path) unless acted upon by an external force.
