Circular motion problem -- A ball rolling down an incline
In summary, a 1 kg ball with a radius of 20 cm rolls down a 5 m high inclined plane with a velocity of 8 m/s at the bottom. Using the equation velocity = 2πr/T, we can solve for T and find that it takes the ball 0.16 seconds to make one revolution. Therefore, the ball makes 6.3 revolutions per second when at the bottom of the plane. This can also be calculated by taking 1/T, where T is the time it takes for the ball to make one revolution.
bijou1
A 1 kg ball with a radius of 20 cm rolls down a 5 m high inclined plane. Its speed at the bottom is 8 m/s. How many revolutions per second is the ball making when at the bottom of the plane?
circumference = 2πr
velocity = distance / time = circumference / time
period (T) = time in seconds
radius = 20 cm ⇒ 0.2 m
mass = 1 kg
velocity at bottom of plane = 8 m/s
The velocity and circumference of a circle is related through the equation
⇒ velocity = circumference / period
⇒velocity = 2πr / T
⇒velocity = ( 2 * 3.14 * 0.2 m ) / T
⇒8 m/s = 1.3 m / T
⇒T = 0.16 s
8 m /1 s so 8 m / 0.16 s = 50 m/s ??
I have trouble getting the revolutions/second for the ball when it is at the bottom of the plane.
Is revolutions/second the equivalency of meters/second for velocity? I know my approach to this problem is incorrect, and so any help would be great. Thanks.
⇒velocity = 2πr / T
⇒8 m/s = 1.3 m / T
You've done fine to this point. Now, just solve for "T." Just as an incidental comment on notation, upper case "T" is usually used for temperature, and time is generally indicated with a lower case "t."
circumference = 2πr
mass = 1 kg
⇒velocity = 2πr / T
⇒8 m/s = 1.3 m / T
⇒T = 0.16 s
The ball makes a full revolution in T seconds, so the number of revolutions per second is 1/T.
The angular velocity is ω=2π/T (radian/second) The linear velocity and angular velocity are related as v=ωr.
Hi, so according to this equation 1/T, the ball makes an "x" number of revolutions per second. Then, from above I found that T = 0.16 s, therefore
1/0.16 s = 6.3 revolutions / second. How did you get the equation 1/T for the number of revolutions/second? Thanks for your help!
If it makes one revolution in T seconds, how long does it take to make N revolutions? What do you get if you set that time equal to 1 second?
It is the same as with the "common" velocity : You walk to reach to your destiny 200 km away in 2.5 hours, what is the distance your car covers in 1 hour? ( The speed of the car is distance covered / time period)
If the ball rotates by the angle θ in t time , the angular velocity is ω=θ/t . Here, the angle rolls the play of "distance covered".
You can measure the angle in complete turns, that is, in terms of 2π radians. For example, If the ball turns 1000 in 10 seconds, the number of revolutions is 1000/10 = 100 in one second. If the ball needs 0.1 s to turn once, then the number of revolutions is 1/0.1 = 10 in one second. If the ball makes a complete turn in T time, the number of revolutions per second is 1/T .
if its rolling without slipping, the surface of the ball is also traveling at 8 m/s, so, how many circumferences fit into 8 metres ?
Hi, so the "distance covered" is 2*3.14*(0.2 m) = 1.3 m and finding "t" through v = 2 π r / t , yielding the answer t = 0.16 s and knowing that the ball makes one revolution in
0.16 s gives the answer (1 revolution / 0.16s ) = 6.3 revolutions / second. Initially I thought I had to divide 1.3 m / 8 m/s, which is completely wrong. Thank you so much for your explanation, and taking the time to explain to me in step by step detail!
Related to Circular motion problem -- A ball rolling down an incline
What is circular motion?
Circular motion is the movement of an object along a circular path or trajectory around a fixed point.
What is the difference between linear and circular motion?
Linear motion is the movement of an object in a straight line, while circular motion is the movement of an object along a circular path.
What is the formula for calculating the speed of an object in circular motion?
The formula for calculating the speed of an object in circular motion is v = rω, where v is the speed, r is the radius of the circular path, and ω is the angular velocity.
How does the incline of an object's path affect its circular motion?
The incline of an object's path affects its circular motion by changing the direction and magnitude of the object's velocity. The steeper the incline, the greater the acceleration and the faster the object's speed will change.
How does the mass of an object affect its circular motion?
The mass of an object does not affect its circular motion directly. However, a heavier object may require more force to maintain circular motion, as it has a greater inertia and is more resistant to changes in its velocity.
