Circular motion problem no idea what's going wrong ><
In summary, the correct banking angle for a highway curve with a radius of 560m and traffic moving at a speed of 73.0km/hr is approximately 90 degrees. However, this solution may be incorrect due to a potential error in assigning forces and the suggestion to rotate the coordinate system for a more accurate calculation.
irNewton
A highway curve of radius 560m is designed for traffic moving at a speed of 73.0km/hr (1216m/s). What is the correct banking angle of the road?
a=v^2/r
F=ma
Forces in t direction:
Fnet=Fncos[tex]\vartheta[/tex]-Fg=0
Fn=mg/cos[tex]\vartheta[/tex]=0
Forces in r direciton:
Fnetr=Fnsin[tex]\vartheta[/tex]=mv^2/r
mgsin[tex]\vartheta[/tex]/cos[tex]\vartheta[/tex]=mv^2/r
tan[tex]\vartheta[/tex]=v^2/r*g
[tex]\vartheta[/tex]=tan-1(1216^2/(9.81*560))
[tex]\vartheta[/tex]= 90 degrees?
which is wrong... = (
double check the way you're assigning your forces, is the Fny component which is cancelling vertical gravity the hypotenuse of the triangle? I find it helpful in these cases to rotate the coordinate system so that the x-axis is actually the sloped road. That way your Fn has only 1 component, and you break down gravity into y & x where x points towards the center of the turn.
It seems that you have made a mistake in your calculations. The correct banking angle can be found using the equation \tan\vartheta=v^2/(rg), where v is the speed, r is the radius, and g is the acceleration due to gravity. Plugging in the given values, we get \tan\vartheta=(1216)^2/(560*9.81)=2.89. Taking the inverse tangent of this value, we get a banking angle of approximately 71.2 degrees. This means that the road should be banked at an angle of 71.2 degrees in order to safely accommodate traffic moving at 73.0km/hr (1216m/s) around the curve.
Related to Circular motion problem no idea what's going wrong ><
1. What is circular motion?
Circular motion is the movement of an object along a circular path. This can occur when an object is revolving around a fixed point or when it is rotating on its own axis.
2. How do you solve circular motion problems?
To solve circular motion problems, you can use equations such as the centripetal force equation (F = mv^2/r) or the tangential velocity equation (v = ωr). It is also important to understand the concepts of centripetal acceleration, tangential acceleration, and the direction of forces in circular motion.
3. What are common mistakes made when solving circular motion problems?
Some common mistakes made when solving circular motion problems include using incorrect equations, not considering all forces acting on the object, and not paying attention to the direction of forces. It is important to double check your calculations and to draw a clear diagram to help visualize the problem.
4. What is the difference between uniform and non-uniform circular motion?
Uniform circular motion is when an object moves at a constant speed along a circular path, while non-uniform circular motion is when the object's speed changes along the path. This can occur when there is a change in the radius or when there are external forces acting on the object.
5. How can circular motion problems be applied in real life?
Circular motion is a common phenomenon in our daily lives. It can be seen in the motion of planets around the sun, the rotation of tires on a car, and the swinging of a pendulum. Understanding circular motion can also help in designing and analyzing machinery and vehicles that involve circular motion, such as amusement park rides and satellites.
