Circular Motion Question searching for Centripetal force
In summary, circular motion is the movement of an object along a circular path, requiring a centripetal force to keep it in its path. Centripetal force is the inward force that acts towards the center of the circular path, necessary for an object to undergo circular motion. It can be calculated using Fc = (mv^2)/r. Centripetal force and centripetal acceleration are directly proportional to each other. Without a centripetal force, an object will continue moving in a straight line due to its inertia.
claytonwideman
A 50 g weight is swung in a circle on the end of a 90 cm long string at the speed of 5.9 m/s, what is centripetal force? [1.9 N]
Vc = (2πr)\T
|a| = v^2/r
Fc = T-Fg (not sure if T is force of tension or period, my teacher,incorrectly,uses it as both)
Fc = T-Fg
T=2πr/v = .95845199...
Fc = T- Fg = -3.946
-3.9 ≠ 1.9 ∴ incorrect
claytonwideman said:
Fc = T-Fg
What directions are T and Fg in? How do you add and subtract forces that act in different directions?
Related to Circular Motion Question searching for Centripetal force
1. What is circular motion?
Circular motion refers to the movement of an object along a circular path around a fixed point or axis. This type of motion requires a centripetal (inward) force to keep the object in its circular path.
2. What is centripetal force?
Centripetal force is the force that acts towards the center of a circular path, keeping an object in its circular motion. It is necessary for an object to undergo circular motion as it balances out the object's inertia, preventing it from moving in a straight line.
3. How is centripetal force calculated?
Centripetal force can be calculated using the equation Fc = (mv^2)/r, where Fc is the centripetal force, m is the mass of the object, v is the velocity, and r is the radius of the circular path.
4. What is the relationship between centripetal force and centripetal acceleration?
Centripetal force and centripetal acceleration are directly proportional to each other. This means that as the centripetal force increases, so does the centripetal acceleration, and vice versa.
5. Can an object move in circular motion without a centripetal force?
No, an object cannot move in circular motion without a centripetal force. Without this force, an object will continue moving in a straight line due to its inertia.
