Circular motion, static friction
In summary: Homework Equations:The centripetal force is provided by a normal force from the cylinder on the ball. Static friction must be preventing the ball from "falling" (that is, static friction cancels out the weight of the ball).
kplooksafterme
47
[SOLVED] Circular motion, static friction
Hey, this is more of a concept question than a homework question, but here goes: If a ball is spun fast enough to move around the inside of a vertical cylinder at a roughly constant velocity for a few seconds without spiraling down the cylinder, what forces are acting on the ball?
I think the centripetal acceleration is provided by a normal force from the cylinder on the ball. Static friction must be preventing the ball from "falling" (that is, static friction cancels out the weight of the ball). I'm unsure about the "tangential" forces- I know the ball moves around the cylinder due to static friction, but I am unsure what force causes the ball to slow down... Is it rolling friction? Is there any occurance of kinetic friction in this situation? Thanks for any help.
The faster it rotates the stronger the centripetal force and thus the stronger the normal force, increasing the force of friction in general(I think you got that much)
Force is a vector, remember. In the down direction the force of gravity is unable to overcome the static friction, like you thought, in the tangential direction there's kinetic friction causing it to slow down, as it slows down, the centripetal and normal force decrease until gravity can start it moving down
So kinetic friction can slow down a rolling object? This seems kind of counter-intuitive.
Well strictly speaking, if it's perfect rolling motion(so no rolling AND translating, all rolling, which requires just the absolute right force of friction at the point of contact)then no energy is lost to friction
If there's not enough friction the wheel or ball or whatever will slip and have that "spin in place" type of effect, if there's too much it'll slide without rolling right, but in ideal perfect rolling motion no, it'll go forever
But from life experience, how many times have you seen something roll forever? So when they say ideal they do mean ideal
well obviously I've never seen something roll forever, but I've never seen something roll in a vacuum. I know air resistance will slow down any moving object, but I also agree that it would be near impossible to perfectly spin an object so it rolls without kinetic friction. My problem I guess is how do I know if the question is assuming this ideal situation or not? We make simplifying assumptions all the time with physics problems (rigid bodies, particle modeling, etc.) I'll try the problem I'm stuck on, this time including kinetic friction and I'll let you know how it goes.
Thanks for your help, it's been much appreciated!
the force of friction is opposing the translational motion down the cyclinder (caused by gravity), not so much the translational motion caused by the ball rolling around the cyclinder.
the forces of concern here are the force of gravity (down), the normal force (radial, and cause of centripital acceration) and the force of friction (up, proportional to the normal force), which govern if the ball holds up in the cylinder or how fast the ball will slide down the cylinder.
True enough, but if in a problem they tell you the angular velocity is constant, there has to be a pretty sizable force counteracting the tangential static friction force. I'm assuming this is kinetic friction, but is this a safe assumption?
Also, the static friction pointing up is equal to the weight; it's proportionality to the normal force is irrelevant, since I'm assuming the ball doesn't spiral down.
Well if you're assuming that then yes
If angular velocity is constant, there's no angular acceleration, and no torque, which is fine, it shouldn't accelerate. The way you say the problem it sounds like there's nothing actively driving it, you get it going then let go and let it do whatever and watch, so yes, angular velocity shouldn't increase any more than something sliding over a frictionless surface with no other forces acting should acclerate
EDIT: The first line is to your most recent post, the big paragraph is to your one before that
Related to Circular motion, static friction
1. What is circular motion?
Circular motion is defined as the movement of an object along a circular path, where the direction of motion is constantly changing.
2. What is the centripetal force in circular motion?
The centripetal force is the force that acts towards the center of the circular path, keeping an object in circular motion. It is always perpendicular to the velocity of the object.
3. How is circular motion related to angular velocity?
Angular velocity is the rate at which an object rotates around a fixed point. In circular motion, the angular velocity is directly proportional to the speed of the object and inversely proportional to the radius of the circular path.
4. What is static friction?
Static friction is the force that prevents two surfaces from sliding against each other when there is no relative motion between them. It is caused by the interlocking of microscopic bumps and ridges on the surfaces.
5. How does static friction affect circular motion?
In circular motion, static friction can provide the necessary centripetal force to keep an object in circular motion. If the static friction force is not sufficient, the object will slip and break out of its circular path.
