MHB Circumcircles Find a formula relating R,R_1,R_2.
  • Thread starter Thread starter mrtwhs
    Formula
In the discussion, a right triangle ABC with legs BC = a, AC = b, and hypotenuse AB = c is analyzed to derive a relationship between its circumradius R and the circumradii R1 and R2 of two isosceles triangles formed by joining two copies of triangle ABC. The isosceles triangle formed with a as the common side has sides c, c, and 2b, leading to circumradius R1. Conversely, the isosceles triangle formed with b as the common side has sides c, c, and 2a, resulting in circumradius R2. The participants are focused on finding a formula that connects R, R1, and R2 based on these configurations. The discussion emphasizes geometric relationships and circumradius calculations in right triangles.
mrtwhs
Let $$\triangle ABC$$ be a right triangle with right angle at $$C$$. Suppose this right triangle has legs $$BC=a$$, $$AC=b$$, hypotenuse $$AB=C$$, and circumradius $$R$$. Two copies of this triangle can be joined to form an isosceles triangle in two ways. With $$a$$ as a common side, you can form an isosceles triangle with sides $$c,c,2b$$ and circumradius $$R_1$$. With $$b$$ as a common side, you can form an isosceles triangle with sides $$c,c,2a$$ and circumradius $$R_2$$. Find a formula relating $$R,R_1,R_2$$.
Mathematics news on Phys.org
My attempt:
For the first circle, we clearly have
$$R=\frac c2$$
as the circumcentre is the midpoint of the hypotenuse $\mathrm{AB}$.
For the second circle, let $\mathrm D$ be the point on $\mathrm{BC}$ extended so that $\angle\,\mathrm{DAB}$ is a right angle. Then $\triangle\mathrm{DCA}$ is similar to $\triangle\mathrm{ACB}$ and so $|\mathrm{DC}|=\dfrac{b^2}a$. The circumcentre is the midpoint of $\mathrm{DB}$ and so
$$R_1=\frac12\left(\frac{b^2}a+a\right)=\frac{c^2}{2a}.$$
By symmetry,
$$R_2=\frac{c^2}{2b}.$$
Hence:
$$c^2=a^2+b^2=\frac{c^4}{4R_1^2}+\frac{c^4}{4R_2^2}$$
$\implies\ \dfrac1{c^2}=\dfrac1{4R_1^2}+\dfrac1{4R_2^2}$
$\implies\ \boxed{\dfrac1{R^2}\ =\ \dfrac1{R_1^2}+\dfrac1{R_2^2}}$.
Olinguito said:
$\boxed{\dfrac1{R^2}\ =\ \dfrac1{R_1^2}+\dfrac1{R_2^2}}$.
Nice! Pretty much the same way I solved it.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
