Circumference and Area of A Circle
In summary: So, to find the radius using the nearest value method, we can use these formulae. However, it may not always give an exact answer as it is an approximation.
susanto3311
73
hello expert...
How to find the circumference of a circle and area of a circle quickly?
it's possible using method like ratio or series like pythagoras theory (3,4,5).
or another way?
somebody could help me out?
cheers...
susanto3311
Mathematics news on Phys.org
What do you know about the circle?
You can find both using the radius (or diameter) of the circle. The main way to find them is also the quickest way
hi guys...
i want to easy find area & circumference of circle to multiple choice exam with "tactics & logic" approach, again like triagle phytagoras concept just know 3,4 the last result must be 5..
I'm still not 100% sure what you're asking. I get the impression you want to know a way of finding the area of a circle without having to work it out in the same way that if you know two sides of a right angled triangle are 3 and 4 then the third must be 5.
If so then the only real shortcut is to learn the results. I would also use exact answers (left in terms of \(\displaystyle \pi\)) as it's both easier to work out and correct (not an approximation).
In multiple choice it may be worth saying \(\displaystyle \pi \approx 3\)
If you're given the diameter instead of the radius then you can use these formulae:
\(\displaystyle C = \pi d\) and \(\displaystyle A = \frac{\pi}{4} d^2 \) where \(\displaystyle d\) is the diameter.
Just remember not to use that approximation too much...
[youtube]V98soOyQWKY[/youtube]
hello guys...
I found the nearest value of area of the circle with a simple trick using vedic maths..
please, read this link http://vedicmathstricks.yolasite.com/
how do make formula for find the nearest value of circumference of the circle?
any ideas?
thanks...
It appears to me what is being done there is to use 22/7 as an approximation for $\pi$ (I recall using this approximation in primary school). If you require more decimal places, then you can use 355/113.
susanto3311 said:
hello guys...
any ideas?
thanks...
using vedic method, how to find easy radius? i mean simple calculation..
If we are given the area $A$ of a circle, or the circumference $C$, then using the rational approximation:
\(\displaystyle \pi\approx\frac{22}{7}\)
then we find:
\(\displaystyle A\approx\frac{22}{7}r^2\implies r\approx\sqrt{\frac{7A}{22}}\)
\(\displaystyle C\approx2\cdot\frac{22}{7}r\implies r\approx\frac{7C}{44}\)
FAQ: Circumference and Area of A Circle
What is the formula for finding the circumference of a circle?
The formula for finding the circumference of a circle is C = 2πr, where C represents the circumference and r represents the radius of the circle.
How do you find the area of a circle?
The formula for finding the area of a circle is A = πr^2, where A represents the area and r represents the radius of the circle.
Can you explain the relationship between the circumference and diameter of a circle?
The relationship between the circumference and diameter of a circle is that the circumference is equal to the diameter multiplied by π (C = πd). This means that the circumference is approximately 3 times the diameter of the circle.
How do you calculate the radius of a circle when given the circumference?
To calculate the radius of a circle when given the circumference, you can use the formula r = C/2π, where r represents the radius and C represents the circumference.
Why is π used in formulas for finding the circumference and area of a circle?
π, also known as "pi", is a mathematical constant that represents the ratio of a circle's circumference to its diameter. It is used in the formulas for finding the circumference and area of a circle because it allows for accurate and precise calculations.
