Citric Acid Cycle -matching carbons
In summary, each pyruvate is a 3 carbon molecule and half of the carbons from a 6 carbon glucose molecule go to each of the two pyruvate molecules. The cleavage of fructose-1,6-bisphosphate by aldolase is the step where you can trace the carbons and numbering them on each step of the pathway can help with tracking.
jenzao
48
Citric Acid Cycle --matching carbons
Which glucose carbons are pyruvate carbons from? I've been trying to get this for hours. please help.. Also how do you trace carbons along the ciric acid cycle?
Each pyruvate is a 3 carbon molecule and glucose is a 6 carbon molecule. Therefore, half of the carbons in a glucose molecule go to each of the two pyruvate molecules. The step where the molecule is cut in half I believe is the step where fructose-1,6-bisphosphate is cleaved by aldolase so you should be able to see which carbons go where by analyzing the result of that step. If you want to track the carbons, the easiest thing to do is to just number them on each step of the pathway.
The pyruvate carbons come from the glucose carbons that enter the citric acid cycle through the conversion of pyruvate to acetyl-CoA. This happens in the cytoplasm during the process of glycolysis.
To trace carbons along the citric acid cycle, you can follow the pathway of acetyl-CoA as it enters the cycle and is converted to citrate. As citrate goes through various reactions, the carbons are rearranged and eventually released as CO2. The remaining carbons are then used to form ATP and other molecules. The key is to keep track of the number of carbons in each molecule and how they change throughout the cycle. You can also use isotopic labeling techniques to track the movement of specific carbons in the cycle.
Related to Citric Acid Cycle -matching carbons
1. What is the Citric Acid Cycle?
The Citric Acid Cycle, also known as the Krebs Cycle, is a metabolic pathway that occurs in the mitochondria of cells. It is responsible for the breakdown of carbohydrates, fats, and proteins to produce energy in the form of ATP.
2. How many carbons are involved in the Citric Acid Cycle?
The Citric Acid Cycle involves a total of 8 carbons. Acetyl-CoA, a two-carbon molecule, enters the cycle and combines with oxaloacetate, a four-carbon molecule, to form citrate, which has six carbons. During the cycle, two carbons are released in the form of CO2, leaving behind a four-carbon molecule to continue the cycle.
3. How does citric acid cycle extract energy from carbohydrates?
The Citric Acid Cycle extracts energy from carbohydrates through a series of redox reactions. These reactions involve the transfer of electrons from the high-energy molecules NADH and FADH2 to the electron transport chain, where they are used to produce ATP.
4. What is the importance of the Citric Acid Cycle in cellular respiration?
The Citric Acid Cycle is a crucial part of cellular respiration, which is the process by which cells convert nutrients into energy. It plays a central role in the breakdown of carbohydrates, fats, and proteins to produce ATP, the main source of energy for cellular processes.
5. What happens to the carbon atoms in the Citric Acid Cycle?
The carbon atoms in the Citric Acid Cycle are ultimately released in the form of CO2. During the cycle, two carbons are released as CO2 in two different steps, while the remaining four carbons are rearranged and recycled to continue the cycle. This process helps to maintain a constant supply of carbon molecules for the cycle to continue producing energy.
