Clarification between electric field and potential energy
In summary: The point of this post is to explain the difference between potential and field. Potential is the energy needed to get an object from a start position to a final position. That applies to electricity and magnetism and also to gravity. If the force is constant with distance, the potential is F X distance moved. Work and Energy are really what counts in life. Force is of rather 'secondary' importance. Voltage (correct term: Potential Difference) tells you the energy available when a charge moves through a Load (heater / light bulb / motor). Potential (Energy) is Force times distanced moved in the direction of the force. It's easier to start off with a charge between two wide plates with V volts across them (the maths is simpler because
Notaphysicsmajor
From my understand, electric field is the force emitting from a charge. This means that if a charge was placed in the vicinity of the charge that was emitting the field of force, that charge placed would experience a force from it. How does potential energy differ from this? I understand that potential energy is in joules, meaning it's work. So does that mean it's the amount of work being done on the charge? Say there is a positive charge there and a negative charged was placed x distance away from it. Would calculating the potential energy from that distance be the amount of work done to bring the two charges together? In this example it would be the positive charge moving towards the negative charge? What would happen if it was two of the same charges in that it would experience an repulsive force, say two positive charges?
In a battery, the amount of volts it provides is the amount of work per coulomb? So it would be providing 1.5 joules per 6.24*10^8 electrons?
The difference is enormous, although, at first sight, they appear the same.
Field produces a Force on an object. Potential is the Energy needed to get that object from a start position to a final position. That applies to electricity and magnetism and also to Gravity. If the force is constant with distance, the potential is F X distance moved.
Work and Energy are really what counts in life. Force is of rather 'secondary' importance. Voltage (correct term: Potential Difference) tells you the energy available when a charge moves through a Load (heater / light bulb / motor). Potential (Energy) is Force times distanced moved in the direction of the force. It's easier to start off with a charge between two wide plates with V volts across them (the maths is simpler because the Field is uniform). The field (E) between the plates, spaced by d, is V/d and it's units are Volts per metre. The potential (work W done moving between the plates will be
Force X distance
which is E X q X d
but E is V/d so Work done is
W = qV
The distance cancels out in those steps which shown that the Work done is independent of the spacing so you can have a whole range of fields for the same work done.
Right idea but the charge on an electron is 1.6^-19C. You will read this message a lot on PF: Electrical Engineering and basic Electrical theory has no need to consider electrons at all. We deal with 'Charge' and we use a unit that's a sensible size (1 A flowing for 1s = 1 Joule). Avoiding electrons helps to avoid trying to give them some sort of mechanical properties like significant Kinetic Energy (which they don't when traveling through a wire).
A potential is a field and you can only measure differences in the field not absolute values at each point. The rate of change of these differences or the first derivative of the potential is the force.
Cheers
Cheers
Electric Potential is NOT Electric Field. They are both defined precisely and they have different units so it is nonsense to say they are the same thing. You can measure Field in one point with a charge and a spring balance. The Field is the gradient of the Potential - "rate of change" implies a variation in time and this has nothing to do with time.
What is the point of leaping into a post with ideas that any textbook could put you right on.
Yes, my apologies, I don't know what I was thinking.
Related to Clarification between electric field and potential energy
1. What is the difference between electric field and potential energy?
The electric field is a physical quantity that describes the force that a charged particle experiences at a given point in space. It is a vector quantity that has both magnitude and direction. On the other hand, potential energy is a measure of the work required to move a charged particle from one point to another in an electric field. It is a scalar quantity and does not have a direction.
2. How are electric field and potential energy related?
Electric field and potential energy are closely related. The electric field at a point is the negative gradient of the potential energy at that point. In other words, the electric field is the rate of change of potential energy with respect to distance. This means that the direction of the electric field is always perpendicular to the equipotential surfaces of the potential energy.
3. Can electric field and potential energy be negative?
Yes, both electric field and potential energy can be negative. A negative electric field indicates that the force on a charged particle is in the opposite direction of the field. Similarly, a negative potential energy means that work must be done against the electric field to move a charged particle to that point.
4. How is electric field and potential energy calculated?
The electric field at a point is calculated by dividing the force on a test charge at that point by the magnitude of the test charge. Mathematically, it can be represented as E = F/q, where E is the electric field, F is the force, and q is the test charge. Potential energy, on the other hand, is calculated by multiplying the charge of the particle by the electric potential at that point. Mathematically, it can be represented as PE = qV, where PE is the potential energy, q is the charge, and V is the electric potential.
5. What are some common real-life applications of electric field and potential energy?
Electric field and potential energy have numerous real-life applications. Some common examples include the functioning of electronic devices, such as televisions and computers, which utilize electric fields to control the movement of charged particles. In the medical field, electric fields are used in procedures like electrocardiograms and electroencephalograms. Potential energy is also used in various energy sources, such as batteries and power plants, to generate electricity.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
