Clarification on different kinds of acceleration
In summary: Yes, you have it right. The angular acceleration vector lies along the rotation axis and its direction is usually assessed by way of the right hand rule (for right-handed coordinate systems).
henry3369
194
Not a homework question, I just need clarification.
I'm slightly confused on the different kinds of accelerations involved in a rotating body. I often see three types of acceleration:
1. radial
2. tangential
3. angular
I'm assuming radial acceleration is the same as centripetal acceleration. So is tangential acceleration the same thing as the linear acceleration of the body being observed while angular acceleration is the acceleration of the rotation (which points in the same direction of the axis of rotation I believe)? Also when a question asks: What is the resultant acceleration of the rotating body, what am I solving for?
1. radial
2. tangential
3. angular
This can sometimes be context dependent, but generally it refers to the total acceleration felt by the body. If you were to draw a Free Body Diagram for the body, it would be sum of all the accelerations acting on it.
So is linear acceleration the same as tangential acceleration?
Or is tangential acceleration a component of linear acceleration?
1. radial
2. tangential
3. angular
yes
in a direction tangent to the curve
yes[, using right hand rule
for pure rotation, the resultant of the tangential and radial accelerations
For rotational motion it is convenient to break the vectors into radial and tangential components rather than x and y components (in a plane). If something is forced to rotate around a point with its radius fixed then there is a centripetal acceleration that points inward; this acceleration just serves to change the direction of motion. A tangential acceleration in this case will result in a change in speed.
it is not a component
the term 'linear acceleration' is most often used in reference to translational acceleration of the center of mass along a straight line, but I suppose it's ok to refer to tangential acceleration as linear acceleration of a particle at any point on the curved path, noting that it's direction is always tangent to the curve.
FAQ: Clarification on different kinds of acceleration
What is the definition of acceleration?
Acceleration is the rate of change of velocity with respect to time. It is a vector quantity, meaning it has both magnitude and direction, and is commonly measured in meters per second squared (m/s^2).
What are the different types of acceleration?
The two main types of acceleration are linear and angular. Linear acceleration is when an object's velocity changes in a straight line, while angular acceleration is when an object's velocity changes in a circular or rotational motion.
How is acceleration related to force?
According to Newton's second law of motion, acceleration is directly proportional to the net force acting on an object and inversely proportional to the object's mass. This means that the greater the force applied to an object, the greater its acceleration will be.
What is centripetal acceleration?
Centripetal acceleration is a type of angular acceleration that occurs when an object moves in a circular path. It is directed towards the center of the circle and is caused by a centripetal force, such as tension in a string or the force of gravity.
How is acceleration calculated?
The formula for acceleration is a = (v2 - v1) / t, where v2 is the final velocity, v1 is the initial velocity, and t is the time taken for the change in velocity to occur. This formula can be used for both linear and angular acceleration.
