Clarification regarding the use of Lambert's Cosine Law
  • Thread starter misterlimbo
  • Tags
    Cosine Law
In summary, to accurately calculate the illumination on the floor around the chair, it is important to use the direct distance from the light source to the chair, rather than just the depth of the bunker. This can be found using the Pythagorean theorem, and the resulting illumination is 1.318 lm/ft2.
misterlimbo
A light bulb is used to light a bunker 10 feet below. A chair sits on the floor of the bunker 3 feet from a spot directly below the bulb. What is the illumination on the floor around the chair if the luminous intensity is 150 candles?
* Lambert's Cosine Law: E(θ) = Ecosθ
where E is the illumination (illuminance) measured at a point "normal" to the source
* E = luminous flux / area = F / A
* luminous flux intensity, I = luminous flux / solid angle = F / Ω
I = F / Ω
I = 150 cd
Ω = 4*pi = 4π steradians
--> F = 600π lumens
E = F / A
E = 600π / [4π*((102 +32).5)2]
--> E = 150/109 lm/ft2 =1.376 lm/ft2
E(θ) = Ecosθ
E(θ) = Ecos(tan-1(3/10))
--> E(θ) = 1.318 lm/ft2
* My question is, did I use the right distance? That is, to use the direct distance from the light source to the chair (which was obtained through Pythagorean theorem) and not just 10ft?
Thanks in advance
for your help!
it is important to accurately represent the physical situation in your calculations. In this case, it is more appropriate to use the direct distance from the light source to the chair, rather than just the depth of the bunker. This is because the light is directly illuminating the chair, and the distance between the light and the chair will affect the amount of illumination received.
Therefore, your calculation using the Pythagorean theorem to find the direct distance of 10.44 feet is correct. This should be used in your calculation for the illumination at the chair's location. Keep up the good work!
Related to Clarification regarding the use of Lambert's Cosine Law
1. What is Lambert's Cosine Law?
Lambert's Cosine Law, also known as the cosine emission law, is an optical phenomenon that describes the brightness of a surface as a function of the angle of incidence of light. It states that the brightness of a surface is directly proportional to the cosine of the angle between the surface normal and the direction of the incident light.
2. How is Lambert's Cosine Law used in scientific research?
Lambert's Cosine Law is commonly used in radiometry, photometry, and remote sensing to describe the directional reflectance and emission of light from surfaces. It is also used in modeling the behavior of light in computer graphics and in the design of lighting systems.
3. Can Lambert's Cosine Law be applied to all surfaces?
While Lambert's Cosine Law is a good approximation for many surfaces, it does not apply to all surfaces. It is most accurate for matte or diffuse surfaces that have a rough texture or a high degree of scattering. Shiny or specular surfaces may not follow this law.
4. How does Lambert's Cosine Law relate to the color of an object?
Lambert's Cosine Law does not directly relate to the color of an object. It only describes the brightness or light intensity of a surface. The color of an object is determined by its spectral reflectance, which takes into account the reflectance of different wavelengths of light.
5. Is Lambert's Cosine Law a universal law of physics?
No, Lambert's Cosine Law is not a universal law of physics. It is an empirical law that has been observed in many natural and artificial surfaces, but it is not derived from fundamental physical principles. It is a useful tool for describing and modeling light behavior, but it has its limitations and exceptions.
  • Differential Equations
