San K
- 911
- 1
I am trying to integrate the following concepts and don't fully understand it:
entanglement, interference, complimentary (two photon vs one photon), uncertainty principle
Perhaps a faq could be made
Below are a set of question and statements please answer/modify/correct where required.
1. Entangled particles don't have single particle interference
however
2. Entangled particles can interfere with each other
3. One photon and two-photon interference is complimentary
as you increase the degree of entanglement, the degree of single particle interference decreases4. In other words, if you have two entangled particles A & B
then the more coherent A is with itself, the less coherent (and hence less entangled) A is with B
5. Entangled particles are always coherent with each other (A is in coherence with B)
6. how does uncertainty principle relate with entanglement?
7. What does coherence within a single particle/photon mean? does it mean the waves (from the photon) that are traveling the various paths --- are all in phase?
8. Single photon interference is known as 2nd order interference (as long as it's entangled with another photon (?))
9. Two- photon (also known as entangled photon) interference is called - forth order interference.
10. In layman terms, roughly speaking:
if you are entangled...
you cannot be self-coherent, but you are coherent wrt the other photon
if you are not entangled...
its possible to be self-coherent (and hence have self-interference)
and
also coherent with some other particle/photon
but then, you are not entangled
however
and
