Classic Vehicle Collision scenario
In summary, the conversation discusses the influence of vehicle mass on injury occurrence in a collision. A specific scenario is presented where a large car and a small car collide head-on, resulting in the larger car sustaining less damage and the smaller car experiencing more severe injuries. This is explained by the fact that the larger car has a higher mass and therefore experiences a smaller change in velocity, resulting in a lower force and less damage. This can be further understood by considering the concept of impulse, where the same force applied to a heavier object will result in a smaller change in velocity and therefore less damage.
adamrobarts
Im hopeless at interperating this, so ill just quote it:
"The masses of the vehicles involved in the collision have significant influence on injury occurence. Suppose a large car of 2000kg and a small car of 1000kg hit head-on when both are traveling at 60km/h. The mass ratio of the cars is 2:1. On collision, if the law of conservation of momentum is applied, the larger car will slow to 20km/h and the smaller car will be instantly propelled backwards at 20km/h. The larger car has a total velocity change of 40km/h while the smaller car has one of 80km/h. It is therefor not suprising that passengers in smaller cars have more severe crash injuries
Present an explanation as to why this factor is important in enhancing/reducing the risk of injury to occupants (Make specific references to physical principals involved)"
Hence its not an answer so much I am looking for, but an explanation.
Since its talking about injury and damage to the car, i immediatly supposed it wanted reference to the Kinetic Energy formula (E=(mv^2)/2) and probably a reference to energy loss using the conservation of momentum theory.
Initial Kinetic energy of the large car = 3,600,000J - the Initial Kinetic energy of the smaller car = 1,800,000J (No suprises there.)
Final Kinetic energies are: 800,000J and 200,000J for the larger and smaller cars respectivly.
The Kinetic energy lost in each case was: 2,800,000J and 1,600,000 for the large and smaller car respectively.
This was as far as i got moreorless; I concluded at this point that it must have sustained more damage because proportional to its mass, it was being subjected to a greater change of energy.
The forces applied to each other is equal, so i can't use that as a way to explain the hightened injury.
Interestingly i was expecting that the changes in energy would be the same - since the work applied to each other was also the same. Peculiar and unexplainable (unless I've missed something and made a mistake)
And that is about as far as I've come - I am probably just thinking in the wrong direction, looking for the wrong things; quite common problem of mine.
Any help would be appreciated.
Cheers, Adam.
As an extra - I had from the beginning thought that if i were able to prove the loss of Kinetic energy was greater for the car (Or something like that) i could explain the aforementioned question. A quicky question perhaps: Now that i have found the losses of each vehicle, how am i able to precisely find how much was lost as heat+deforation etc and on which vehicles. For example - from this information i could say, "the smaller car lost 1,600,000J as deformation etc - which the larger one lost 2,800,000J as heat etc. Or i could switch it as vice versa. Is there really any clear way of knowing?
Sorry - but my mind is really hanging on this question - I am sure everyone knows what that feels like.
- I've noticed that i am not getting responses; possibly because of the complexity of my explanation. Ill simplify it in one sentence.
<b> If a car1 has a head on collision with car2 (with car 2 being twice the mass of car1), and both were traveling at the same velocity, then why would the less massive car 1 sustain more damage and its occupants mroe severe injuries. </b>
This is my last question for the week - and i probably won't sleep until i get it >_<
If you need more detail just ask - If youre confused note it - If you can help, please do so
Just a thought--have you tried using impulse?
I hadnt, but i just tryed...I think i can see the light.
Is my conclusion basically that the same force on a heavier car results in less damage and injury...Sorry if I am a tad thick, But staring at this question for such a long time now - i really want to understand it.
Thanks a lot mbrmbrg - you have really nailed it for me i think. Just to clarify though.
I'd love to clarify it, but I can't really remember it so well, and at 1:45am my time, I will not let myself look it up. However, you are correct (as the problem tells you you will be:wink: ) in concluding that the heavier car will sustain less damage.
Thanks a lot mbrmbrg- i think youve saved my sanity. And yea - I am already sure that the larger car would sustain less damage ;) the only thing i have to do is explain it. But it seems fairly obvious now that I've considered the 'force' side of things.
Still, if anyone can assure me theyre welcome to ^_^
Thanks again . Peace.
FAQ: Classic Vehicle Collision scenario
What is a Classic Vehicle Collision scenario?
A Classic Vehicle Collision scenario refers to a situation where two or more classic vehicles, typically defined as vehicles that are at least 20 years old, are involved in a collision resulting in damage to the vehicles and potentially injuries to the individuals involved.
What are the common causes of Classic Vehicle Collisions?
The common causes of Classic Vehicle Collisions include driver error, mechanical failures, road conditions, and weather conditions. These factors can be exacerbated by the age and condition of the vehicles involved.
How can Classic Vehicle Collisions be prevented?
Classic Vehicle Collisions can be prevented by regularly maintaining and servicing the vehicles, avoiding driving in hazardous weather conditions, following traffic laws and regulations, and staying alert and focused while driving.
What should I do if I am involved in a Classic Vehicle Collision?
If you are involved in a Classic Vehicle Collision, the first step is to ensure the safety of yourself and others involved by moving to a safe location and calling for emergency assistance if necessary. Then, exchange information with the other drivers and document the scene with photos or videos. It is also important to report the incident to your insurance company.
Are there any special considerations when repairing classic vehicles after a collision?
Yes, there are special considerations when repairing classic vehicles after a collision. It is important to use original or high-quality replacement parts, work with experienced mechanics who are familiar with classic vehicles, and carefully document all repairs and modifications for insurance purposes.
