I Classical field in quantum field theory?
Tan Tixuan
In quantum field theory, we have the following expansion on a scalar field (I follow the convention of Schwarz's book)
$$\phi(\vec{x},t)=\int d^3 p \frac{a_p exp(-ip_\mu x^\mu)+a_p^{\dagger}exp(ip_\mu x^\mu)}{(2\pi)^3 \sqrt{2\omega_p}} \quad p^{\mu}=(\omega_p,\vec{p})$$
With commutation relation
$$[a_q,a_p^{\dagger}]=(2\pi)^3 \delta^3 (p-q)$$
We can construct a coherent state of the field by the following, with $\beta_p\equiv \beta(p)$
$$|C\rangle=exp\{-\frac{1}{2}\int d^3p |\beta_p|^2\}exp\{\int \frac{d^3p}{(2\pi)^\frac{3}{2}} (\beta_p a_p^{\dagger})\}|0\rangle$$
It is then not hard to verify that the field expectation value is
$$\langle C|\phi|C\rangle=\int \frac{d^3 p}{(2\pi)^{3/2}}\frac{\beta_p e^{-ip^{\mu}x_{\mu}}}{\sqrt{2\omega_p}}+H.C.$$
**My question is the following**:
It seems to me that ##\phi## is only a simple addition of a bunch of independent harmonic oscillators, and the value of ##\beta(p)## can be determined totally arbitrarily,**i.e. there is no a priori way to determine the dependence of $\beta$ on p . I want to know what is the reasonable way to determine this dependence.** For example, we can make ##\beta(p)## be non-zero only for ##p=0##, and then we would only be left with one simple harmonic oscillator, and the resulting field expectation value is
$$\langle C|\phi|C\rangle\sim cos(mt+\beta_0)$$However,it is often said in the literature that classical field is produced by the coherent state, especially in the study of dark matter cosmology. For example, in [this paper][1], equation 2.3, it is assumed that because the occupation number is huge, the dark matter field is almost classic, and can assume the profile
$$\phi_1(\vec{x},t)=A(\vec{x})cos(mt+\alpha(\vec{x}))$$
In this case, how should I construct ##\beta_1(p)## corresponding to ##\phi_1##, and what is the justification for this kind of profile?(the profile of ##\beta##). i.e. how should I describe it in terms of quantum field theory?
[1]: https://arxiv.org/abs/1309.5888
Likes Demystifier
There is no single possible assignment. A classical field generally depends on the spacetime event (or the Fourier transform depends on the 4-momentum). It depends on the actual realization of the field you want.
Edit: And yes, the quantum field in a non-interacting field theory is just a bunch of harmonic oscillators.
So are you saying that the assignment I propose, that ##\beta## being a delta function is a valid assignment?
That would, in essence, be a plane wave.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
