Classical Mechanics - Coriolis Force
In summary, the Coriolis force is a result of the combination of rotational and linear motion. The equation for the force is -2\omega x VRotating - \omega x (\omega x XRotating). However, the observer on the rotating disk does not observe the effect because their velocity frame of reference already takes into account the rotational motion of the disk. This is why the Coriolis force is zero for the observer on the disk.
macrsp
This is a fairly general problem that came up while trying to model a system. Given a rotating disk and an inertially fixed object, how is the fictional coriolis force handled? For example, if there is a dot on the ground below a sheet of transparent plastic rotating at speed [itex]\omega[/itex], does an observer on the sheet of plastic observe the coriolis affect, and why or why not?
The relevant subset of the relevant equation,
aRotating = - 2[itex]\omega[/itex] x VRotating - [itex]\omega[/itex] x ([itex]\omega[/itex] x XRotating)
Well, the motion can be correctly described by the
portion of the equation.
However, because there is apparent rotation, there is a VRotating, so
is non zero, which makes no sense. I'm probably making a very simple mistake somewhere, and I suspect that it has to do with V being the velocity in the fixed frame, not the rotating frame, but all the explanations of the coriolis equation seem to state it with the velocity being from the rotating frame.
Hello, thank you for bringing up this interesting problem. The Coriolis force is a result of the combination of the rotational motion and the linear motion of an object. In this case, the rotating disk is providing the rotational motion and the inertially fixed object is providing the linear motion. The Coriolis force is given by the equation you have provided, -2\omega x VRotating - \omega x (\omega x XRotating).
To understand why the observer on the rotating disk does not observe the Coriolis effect, we must first understand how the velocity vector is defined in this scenario. In this equation, V is the velocity of the object in the inertial frame, not the rotating frame. This means that the observer on the rotating disk will see the object moving with a velocity V, while an observer in the inertial frame will see the object moving with a velocity of V + \omega x XRotating.
This means that the Coriolis force, which is dependent on the difference in velocities, will be zero for the observer on the rotating disk. This is because the observer on the disk is already accounting for the rotational motion of the disk, and therefore does not see any difference in velocities between the object and the disk.
In conclusion, the observer on the rotating disk will not observe the Coriolis effect because their frame of reference already takes into account the rotational motion of the disk. I hope this helps clarify the issue. Please let me know if you have any further questions.
Related to Classical Mechanics - Coriolis Force
1. What is Coriolis Force in classical mechanics?
Coriolis Force is a fictitious force that appears to act on objects moving in a rotating reference frame. It is caused by the rotation of the Earth and other celestial bodies.
2. How does Coriolis Force affect objects in motion?
Coriolis Force causes objects in motion to deflect to the right in the Northern Hemisphere and to the left in the Southern Hemisphere. This deflection is due to the Earth's rotation and the tendency of objects to maintain their original direction of motion.
3. What is the relationship between Coriolis Force and the Earth's rotation?
Coriolis Force is directly proportional to the angular velocity of the Earth's rotation. This means that the faster the Earth rotates, the stronger the Coriolis Force will be.
4. How is Coriolis Force used in classical mechanics?
Coriolis Force is used to explain phenomena such as the rotation of storms and the direction of ocean currents. It is also taken into account in the design of structures such as bridges and tall buildings to ensure stability.
5. Can Coriolis Force be observed in everyday life?
Yes, Coriolis Force can be observed in everyday life, particularly in weather patterns. For example, hurricanes and typhoons rotate in a counterclockwise direction in the Northern Hemisphere and in a clockwise direction in the Southern Hemisphere due to the Coriolis Force.
