Classical mechanics: Square well with Bounded particle
In summary, the conversation discusses the possibility of having negative energy in classical mechanics. It is stated that negative total energy can exist as long as an arbitrary constant is added or subtracted from the potential energy. The question of how to measure the height for potential energy calculations in relation to Earth's gravity is also raised. The conversation concludes by mentioning the need to repost the question in a homework forum.
Jozefina Gramatikova
64
50288802_758179237899437_8167705243417575424_n.jpg?_nc_cat=106&_nc_ht=scontent.flhr4-1.jpg
My question is can we have negative energy in classical mechanics? Also I would need help for finding the velocity in part b)
  • 50288802_758179237899437_8167705243417575424_n.jpg?_nc_cat=106&_nc_ht=scontent.flhr4-1.jpg
Can we have negative TOTAL energy in classical mechanics?
Yes, because you can always add or subtract an arbitrary constant from the potential as long as you do it everywhere. The potential energy of an object in the Earth's gravity Is ##U=mgh## - but do I measure the height from sea level or from where I'm standing, or somewhere else?
For the rest of the problem, we're going to ask you to repost this question in the homework forum and using the homework template as the forum rules requires. This thread is closed.
Related to Classical mechanics: Square well with Bounded particle
1. What is classical mechanics?
Classical mechanics is a branch of physics that studies the motion of macroscopic objects based on Newton's laws of motion.
2. What is a square well in classical mechanics?
In classical mechanics, a square well is a potential energy function that has a constant value inside a certain range and is infinite outside of that range. It is often used to model the behavior of a particle confined to a certain region.
3. What is a bounded particle in classical mechanics?
A bounded particle in classical mechanics is a particle that is confined to a certain region due to the presence of a potential energy well. This means that the particle's energy is limited and it cannot escape from the well without an external force.
4. How is a square well with a bounded particle modeled in classical mechanics?
In classical mechanics, a square well with a bounded particle is modeled using the Schrödinger equation, which describes the behavior of quantum particles. The solution to this equation gives the allowed energy levels and corresponding wave functions for the particle in the well.
5. What are the applications of a square well with a bounded particle in classical mechanics?
A square well with a bounded particle has many applications in physics, including modeling the behavior of atoms, molecules, and other quantum systems. It also has applications in solid state physics, where it is used to study the electronic properties of materials.
