Classical statistical physics -- Number of microstates
In summary: In the early days of quantum mechanics this problem was called the "Hartree-Fock paradox" after the two British physicists who first raised it.In summary, phase volume is it the same as the number of total microstates in some physical system? Phase volume= volume of phase space. Or there is some difference?
LagrangeEuler
717
Phase volume is it the same as the number of total microstates in some physical system? Phase volume= volume of phase space. Or there is some difference?
In the case of systems with a continuum of states (e.g. a classical gas) the concept of "number of states" is not well defined I think: let A be a state and B a second state, identical to A, but with this difference:
##v_i^A = (v_x,v_y,v_z) → v_i^B = (v_x + ε, v_y,v_z) ##
where ##i## is the label of a generic (tipically identical to some other) particle. Well, states A and B are different and there is no way to count the minimum number of states for the system to go from A to B. It's a consequence of the continuity of phase space (continuity of energy, if you prefer).
In the case of classical systems with discrete states (e.g. Ising model) the volume of phase space is no more considered (you cannot do an integral over that space, as far as I know). It is usually considered a space of configuration (e.g. in the one dimensional Ising model with only spin up or down and ##N## sites, it is a space with all the possible ##N##-dimensional vector with component ##±1##). In this case the number of states is the number of element in this set (the cardinality of the set). As far as I know, this number is usually calculated "indirectly", in the sense that you do considerations over the number of degrees of freedom and simmetries (in principle you can calculate it summing ##1## for each state but you should know them all, i.e. you should know their number.)
I think that's right, but try to check what I told you.
The problem is that classical statistical mechanics is plagued with conceptual problems which are easily solved only with quantum theory. To count microstates the most simple way is to introduce a finite volume, periodic boundary conditions for the Schrödinger wave function and then calculate the states contained in a momentum volume ##\mathrm{d}^3 \vec{p}##, which turns out to be ##V \mathrm{d}^3 \vec{p}/(2 \pi \hbar)^3## in the large-volumen/thermodynamical limit (for bosons the limit is not that trivial due to the formation of a Bose-Einstein condensate at low temperatures, but that's far from the realm where the classical (Boltzmann) limit is valid).
Yeah, one example of a problem of the type vanhees71 probably meant is the "paradox" that the entropy of any fluid should be increasing all the time without bound because its mixing with itself by diffusion isn't really different from the mixing of two different fluids (in classical mechanical reasoning).
Related to Classical statistical physics -- Number of microstates
1. What is the concept of "number of microstates" in classical statistical physics?
The number of microstates refers to the total number of possible arrangements or configurations of a system of particles at a given energy level. In classical statistical physics, this concept is used to describe the distribution of particles in a system and their corresponding energy levels.
2. How is the number of microstates related to entropy?
The number of microstates is directly related to entropy, which is a measure of the disorder or randomness in a system. As the number of microstates increases, so does the entropy, indicating a higher level of disorder in the system.
3. How does the number of microstates change with temperature?
The number of microstates typically increases with temperature. This is because at higher temperatures, the particles in a system have more energy and can move around more freely, resulting in a greater number of possible configurations.
4. What is the significance of the number of microstates in thermodynamics?
The number of microstates is crucial in understanding the behavior of thermodynamic systems. It helps to explain the relationship between energy, temperature, and entropy, and plays a key role in determining the equilibrium state of a system.
5. Can the number of microstates ever decrease?
No, the number of microstates can never decrease in a closed system. According to the second law of thermodynamics, the entropy of a closed system will always increase or remain constant, meaning the number of microstates will also stay the same or increase over time.
  • Thermodynamics
  • Thermodynamics
  • Classical Physics
  • Thermodynamics
