Classification of a second order partial differential equation
The discussion revolves around classifying a second-order partial differential equation and understanding the associated matrix representation. The matrix is derived from the equation's terms, with the off-diagonal elements reflecting symmetry, where factors appear due to the nature of mixed derivatives. Classification criteria are outlined based on eigenvalues, with conditions for elliptic, hyperbolic, and parabolic types depending on the signs and non-zero status of the eigenvalues. Clarifications are provided regarding the interpretation of eigenvalues, particularly that x^2 is always positive, which simplifies the classification process. The conversation emphasizes the importance of understanding the matrix structure and eigenvalue implications for accurate classification.
sylent33
classify the partial differential equation
DE solving
Hello! Consider this partial differential equation
$$ zu_{xx}+x^2u_{yy}+zu_{zz}+2(y-z)u_{xz}+y^3u_x-sin(xyz)u=0 $$
Now I've got the solution and I have a few questions regarding how we get there. Now we've always done it like this.We built the matrix and then find the eigenvalues.
And here is where my first question arrives. I am not sure how they arive at this matrix.
$$ \left[ \begin{matrix} z & 0 & y-z \\\ 0 & x^2 & 0 \\\ y-z & 0 & z \end{matrix} \right] $$
Now I am guessing that the xx,yy,zz are the diagonal,and that is okay,but I am not sure how get the y-z at the bottom left corner? Its "coordinates" are xz meaning top right,why is it in the bottom left as well? Also what happened to the 2 infront of it?
Now after finding the eigenvalues (I know how to that) we get that the eigenvalues are;
##\lambda_1 = z ##
##\lambda_2 = x^2 ##
##\lambda_3 = z ##
And now comes the second part I don't understand.According to the book we are using for this class the classification should be done like this (and I quote)
elliptic if all EV of A(x) are non-zero and have the same sign
(ii) hyperbolic if all EV of A(x) are non-zero and have different signs.
(iii) parabolic if one or more EW of A(x) is zero.
Okay,and now the solutions are given like this;
Elliptic when : ## x\neq 0 \wedge z>0 ##
Hyperbolic when : ##x\neq 0 \wedge z<0 ##
Parabolic when : x = 0 or z = 0 or x and z = 0
Now the parabolic one,at least to me makes sence.Because it covers all the "cases" if you will.But the first 2 just don't click with me,
The fact that ALL of the EV should be non zero shouldn't we also say z unlike 0? and that they have the same sign,at least to me we are saying that all EV are positive,but nothing says what the sign of x is,it just states that is nonzero it might as well be negative.
Same for the hyperbolic, we are only stating that z is negative,but how do we know that x is positive?
Thanks and sorry for the long post.
sylent33 said:
Homework Statement:: classify the partial differential equation
Relevant Equations:: DE solving
For the off-diagonals, there are a factor of two because the matrix is symmetric and ##u_{xz} = u_{zx}##.
If ##z>0## (as explicitly stated in case 1) then it cannot be zero.
Because the eigenvalue that depends on ##x## is positive regardless of the sign of ##x## (it is ##x^2##).
I observe the equation is written as
Tr[\begin{bmatrix}<br /> z &amp; 0 &amp; y-z \\<br /> 0 &amp; x^2 &amp; 0 \\<br /> y-z &amp; 0 &amp; z \\<br /> \end{bmatrix}<br /> \begin{bmatrix}<br /> u_{xx} &amp; u_{xy} &amp; u_{xz} \\<br /> u_{yx} &amp; u_{yy} &amp; u_{yz} \\<br /> u_{zz} &amp; u_{zy} &amp; u_{zz} \\<br /> \end{bmatrix}<br /> -<br /> \begin{bmatrix}<br /> 1 &amp; 0 &amp; 0 \\<br /> 0 &amp; 1 &amp; 0 \\<br /> 0 &amp; 0 &amp; 1 \\<br /> \end{bmatrix}<br /> \frac{sin(xyz)}{3}u]=0
Is it helpful ?
Oh its x squared...well that makes sense now,thanks for pointing it out.
But I didnt get the part with the off-diagonal as such, what do you mean by "For the off-diagonals, there are a factor of two because the matrix is symmetric",I know that the matrix,and if I understood you correctly (not sure I did) if we had it given as 3(y-z) would ##u_xz = u_zx## still hold true,since the matrix is symmetric? Or is it because of the 2 infront (in the example i just gave 3) of the apprentacies.
No. There is a factor of 2 between the differential equation and the entries in the matrix. Technically the matrix tells you that you have ##(y-z)(u_{xz} + u_{zx})## but this is equal to ##2(y-z)u_{xz}##. If you had ##3(y-x)u_{xz}## in the equation then the matrix entries would be ##3(y-z)/2##.
Makes sence,also I see the x squared as well now.Thanks for the help as always
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
