Classifiers, threshold, and ROC curve
  • Thread starter Thread starter fog37
    Threshold
A classifier is a machine learning model that categorizes data into two or more classes. Classifiers can be probabilistic, providing a probability score compared against a threshold (commonly 0.5) for decision-making, or deterministic, which do not necessarily rely on a threshold. The discussion highlights the ability to plot the ROC curve for binary classifiers, which is influenced by true positive rate (TPR) and false positive rate (FPR) across various thresholds. However, there is debate over whether all deterministic classifiers utilize a threshold for decision-making and whether ROC curves can be plotted for any classifier type. The term "deterministic classifier" is not widely recognized, and the diversity of classification algorithms complicates generalizations. Additionally, some algorithms like K-nearest neighbors (KNN) and support vector machines (SVMs) can function as both classifiers and predictors, further adding to the complexity of classification discussions in machine learning.
fog37
TL;DR Summary
Hello,
A classifier is a ML model that can classify between 2 or more classes. Some classifiers are called probabilistic in the sense that they output a probability score that is then compared against a threshold value (usually 0.5) to make the class decision. Other classifiers are not probabilistic...I guess they are called deterministic. We can always plot the ROC curve for a binary classifier. The ROC curve depends on TPR, FPR and various explored threshold values. The TPR and FPR vary for different threshold values...
Do all deterministic classifiers make their decision also based on some set threshold? If so, does it mean that we can plot the ROC curve for any classifier, probabilistic or not?
Thank you!
Technology news on Phys.org
fog37 said:
TL;DR Summary: Classifiers, threshold, and ROC curve
Hello,
Thank you!
I'm not aware of any probabilistic classifier. Usually you just compare the predicted with the actual known value/class of elements in the Testing set., all, like you said, given a threshold, so that, e.g., a threshold of 0.6 will give us a given Confusion Matrix Can you give us examples of probabilistic classifiers?
No, that is not what a probabilistic classifier does: https://en.wikipedia.org/wiki/Probabilistic_classification
No: first of all the term 'deterministic classifier' is not generally recognised, and secondly you should revise your understanding of this material and consider whether your question makes sense given the diversity of classification algorithms.
Once you have revised this material you should be able to see whether this question is relevent.
Confusingly, Knn is sometimes described as a predictor, some times as a classifier.
Yes, in a field as diverse and dynamic as machine learning categorisation and making generalisations in the way the OP is trying to do is IMHO a waste of time.
Same goes for SVMs, also listed for both Classification and Regression
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
