Classifying singularities of a function
penroseandpaper
Classify the singularity for the function
$$ f(z)=\frac{cos(z)} {(z-π/2)^7} $$
Theorems and lemmas related to essential singularities, poles and removable singularities.
I came across this question on chegg for practice as I'm self learning complex analysis, but became stumped on it and without access to the solution am unable to check.
Let $$ f(z)=\frac{cos(z)} {(z-π/2)^7} $$. Then the singularity is at π/2. And on first appearance, it looks like a pole of order 7. However, multiplying by $$(z-π/2)^7 $$ and taking the limit evaluates to zero - meaning it isn't a pole of order 7.
Similarly, the limit of f(z) doesn't exist either, so it can't be a removable singularity.
That must mean it is essential. But is that right and how can I go about proving that, other than showing the above are true leaving only the essential singularity as an option.
Thanks,
penroseandpaper said:
...it can't be a removable singularity.
That must mean it is essential. But is that right ...
No it's not right because not all non-removable singularities are essential. An essential singularity is a singularity that is not a pole of any order. Removable singularities are poles of order 0. So the point ##\pi/2## could be a pole of some finite order. That order cannot be greater than 7 since ##g(z):= f(z)(z-\pi/2)^7=\cos z## is holomorphic.
Since you have shown the pole doesn't have order 7, I suggest you investigate whether it has order 6. If that doesn't work try 5. I'd be surprised if the order were lower than 5.
Consider the Taylor series expansion of cos(z) at z=##\pi/2##. You know what the derivative of cos(z) is so you should know something about a coefficient in the Taylor series. Use that to determine the order of the pole of f(z).
There are other possible orders of the pole. A zero of cos(z) of order n will make the pole of f(z) be a pole of order 7-n.
It is not an essential singularity.
