Cleaning copper connections for high precision instruments
In summary, there are several methods for cleaning copper, including using lemon juice and salt, vinegar and salt, ketchup, commercial copper cleaners, baking soda and water, specific copper cleaning products, ammonia solution, lemon and baking soda, and boiling water and salt. After cleaning, you may want to apply a copper polish or wax to prevent future tarnishing. It is important to be gentle and thorough in the cleaning process to avoid scratching the copper surface.
marcel
Hi all,
Here's my first post with a question I've been trying to solve for a while.
I work with electronic components of very high quality and we try to make all our connections using thin copper ribbons of various thickness. I have started cleaning my copper connections with a solution of vinegar and salt (more or less 3g of salt in 200ml vinegar). I believe that combination yields sodium acetate and hydrogen chloride. It gets rid of any oxidation on the copper. Even copper that looks very clean appears much brighter and cleaner when the solution is applied.
My problem is what happens after the procedure: the piece of copper after a while becomes much more oxidized than before (the new oxidation starts to become visible after a few hours). I have started to clean the copper with isop. alcohol, which sometimes works well, and sometimes doesn't. I suspect the piece must be scrupulously cleaned in order not to oxidize again (in the rate described), which is sometimes very difficult. (Let me add that this is a problem because often I must clean the parts a couple of days before soldering them, and in other cases the connection is merely mechanical).
My question is whether any good soul here would know how to "neutralize" the sodium acetate/ hydrogen chloride solution right after it has cleaned the copper. The reason why the copper oxidizes really fast if I don't clean the solution with alcohol and why it doesn't when I do is beyond me. At any rate, I am looking for a more practical way to maintain the copper bright and clean after using the vinegar solution, for as I said cleaning it with alcohol is very time consuming in order to be effective.
Thanks in advance for any help.
Marcel
Chemistry news on Phys.org
marcel said:
Hi all,
Marcel
Welcome to the PF, Marcel.
Can you post some pictures of the connections you are making?
The standard for good electrical connections came from Bell Labs (in my experience) -- make multiple connections with sharp pointed contacts, and make them gas-tight (which eliminates oxidation). Is there any way you can use that paradigm to improve your electrical contacts?
Hi there,
I'm sorry, but that was not what I asked. I guess my main question is why the copper piece needs to be rinsed after the vinegar solution is applied? Why the solution produces the fast oxidation if it's not rinsed off after it cleaned the copper piece?
Copper is a versatile metal used in various applications, including cookware, pipes, and decorative items. Over time, copper can develop tarnish or patina, which affects its appearance. Here are several methods for cleaning copper:
  1. Lemon Juice and Salt:
    • Cut a lemon in half and dip it in table salt.
    • Rub the lemon over the copper surface.
    • Rinse with water and dry with a soft cloth.
  2. Vinegar and Salt:
    • Mix equal parts of white vinegar and table salt to form a paste.
    • Apply the paste to the copper and let it sit for a few minutes.
    • Scrub with a soft cloth or a toothbrush.
    • Rinse and dry.
  3. Ketchup:
    • Apply ketchup to the tarnished area.
    • Let it sit for a few minutes.
    • Scrub with a soft cloth or toothbrush.
    • Rinse and dry.
  4. Commercial Copper Cleaners:
    • There are commercial copper cleaners available. Follow the manufacturer's instructions when using them.
  5. Baking Soda and Water:
    • Make a paste with baking soda and water.
    • Apply the paste to the copper.
    • Scrub gently and rinse thoroughly.
  6. Copper Cleaning Products:
    • There are specific copper cleaning products on the market that can help remove tarnish and restore the shine. Follow the product instructions.
  7. Ammonia Solution:
    • Mix equal parts of ammonia and water.
    • Soak the copper item in the solution for a short time.
    • Rinse and dry.
  8. Lemon and Baking Soda:
    • Mix baking soda with lemon juice to form a paste.
    • Apply the paste and scrub the copper.
    • Rinse and dry.
  9. Boiling Water and Salt:
    • Line a pot with aluminum foil.
    • Fill it with water and add a few tablespoons of salt.
    • Place the tarnished copper items in the pot and boil for several minutes.
    • Rinse and polish.
After cleaning the copper, you may want to apply a copper polish or wax to help prevent tarnishing in the future. Be gentle when cleaning to avoid scratching the copper surface, especially on items with decorative patterns or finishes. Always rinse and dry thoroughly to prevent water spots.
Again... why is it formed if the vinegar solution is not rinsed off?
The residual traces of vinegar and other chemicals will continue to attack the copper surface after all oxide has been removed .
Vinegar and salt could potentially form several different compounds with copper but most problematic one for you is likely to be copper acetate . In thin film form not easily distinguishable from copper oxide .
To prevent this continuing attack on your copper surfaces scrupulous removal of residues is essential . Alcohol is probably not best cleaner . There are specially formulated cleaning and passivating agents available for this purpose .
Citric acid may be better than Vinegar/salt for your purpose of removing oxides from copper .
Citric acid has a relatively gentle cleaning action and residues can be easily washed off with mild detergent solutions followed by plain water .
It is not just the low pH that etches the oxides, from what I remember presence of chlorides plays a crucial role. Replacing vinegar with other acid won't change that.
Thank you, that's helpful. I've tried lemon instead of vinegar, but it creates a similar if not the same problem. Washing in water is not an option, unfortunately. The cleaning needs to be done in place, on rather small connections. I generally do everything with qtips, which obviously is a very limited procedure as far as the capacity to completely remove the acid.
Why is copper acetate more problematic than oxidation?
What do you suggest instead of alcohol?
thanks.
They all work quite well and leave no visible residue .
Brass and copper materials treated with these products do though seem to be protected from atmospheric corrosion for at least several hours after application so there must be some very thin protective film left on components .
marcel said:
thanks.
What I meant was that your Vinegar/salt mix removes the copper oxide but can replace it with copper acetate . Really you want neither .
Copper acetate is an unpleasant greasy substance that is difficult to clean off entirely once formed except by abrasive methods . Best therefore to entirely prevent it's formation by removing any Vinegar/salt residue on components completely and immediately after their use .
Got it, thanks again. Question: if we leave the acetate layer there, would it be more corrosive than oxidation in the long run?
Copper oxide thin films are relatively benign and slow forming in ordinary atmospheric conditions .
Copper acetate once first formed seems to remain active and continue to corrode into the parent metal for long periods .
As you see in the Verdigris link the chemical substance that actually forms over long periods of time gets to be far more complex than simple Copper acetate and there can be several different formation and corrosion mechanisms at work .
There is a similar problem with some acid flux residues after soldering . Unless scrupulously removed they seem to continue causing corrosion forever .
very helpful, thank you.
Someone else has just suggested something that might do the trick: instead of alcohol, use an alkaline solution (eg water with baking soda) to both neutralize the acid (acetic or citric) and finalize the cleaning. I would then simply dry the piece with a hair drying. What do you think?
Dilute aqueous solutions of baking soda and other chemicals like Sodium Hydroxide are often used for neutralising acid residues on manufactured items but always in conjunction with a final rinse with clean water .
The final rinse is essential to avoid problem of leaving new residues on components which could be as harmful as the ones that have been removed .
No doubt.
I have tried the baking soda after the acid. I'm not sure it does what it supposes to do. When I clean with the vinegar/salt solution I can see on the white tissue I use the blue residual of the oxidation: the copper looks perfectly clean. Then when I apply the water/baking soda solution to neutralize the vinegar, the tissue shows a yellow residue and the copper acquires a slight shadow (not really uniform). If I clean again the same copper with vinegar it gets rid of the shadow and shines again...
and no, the final rinse with water did not change things. It actually looks better if I only rinse it with water without the soda.
Further thoughts :
Vinegar is not chemically pure acetic acid . It contains various residues from the manufacturing process and sometimes deliberately added ingredients such as caramel .
Also salt and baking soda often have anti-caking agents added .
Some of your problems may originate from these additives .
It may be expedient to use laboratory grade pure chemicals for further experiments .
Ok, thanks for the tip.
Related to Cleaning copper connections for high precision instruments
1. How do I clean copper connections for high precision instruments?
To clean copper connections for high precision instruments, you will need a cleaning solution specifically designed for copper, a soft cloth or brush, and distilled water. First, use the cleaning solution to remove any dirt or grime from the connections. Then, rinse with distilled water and dry with a soft cloth or let air dry.
2. Can I use any cleaning solution for copper connections?
No, it is important to use a cleaning solution specifically designed for copper to avoid damaging the connections. Other cleaning solutions may contain harsh chemicals that can corrode or discolor the copper.
3. How often should I clean copper connections for high precision instruments?
The frequency of cleaning will depend on the environment and usage of the instruments. In general, it is recommended to clean copper connections at least once a month to maintain optimal performance.
4. Is it necessary to dry the connections after cleaning?
Yes, it is important to dry the connections after cleaning to prevent any moisture from causing corrosion. Using a soft cloth or allowing the connections to air dry is the best method.
5. Can I use abrasive materials to clean copper connections?
No, abrasive materials such as steel wool or harsh scrubbing brushes should not be used to clean copper connections. These materials can scratch or damage the connections, affecting their performance and longevity. Stick to using a soft cloth or brush and a gentle cleaning solution.
  • General Engineering
  • Chemistry
