Clock Synchronisation -- Do clock speeds go out of synch?
In summary, the article discusses the phenomenon of clock synchronization and explores whether clock speeds can drift out of sync over time. It explains that factors such as temperature variations, hardware differences, and manufacturing tolerances can cause discrepancies in clock speeds. The importance of synchronization in various applications, especially in computing and telecommunications, is emphasized, along with methods used to achieve accurate synchronization, including network time protocols and specialized hardware solutions.
  • #36
Mister T said:
And if they're co-located you can't use them to measure the speed of a beam of light that moves from one clock to the other. I thought that measuring the one-way speed of light was your main concern?
I didn't express any concern. The OP question was if synchronization as used in SR requires the clocks to show the same time or them running at the same rate is enough. I answer that they have to show the same time to be called synchronized in SR. I didn't notice anything regarding measuring the one-way speed of light in this thread.
Likes Dale
  • #37
It is in the OP
Phil42 said:
When reading about the one way speed of light, I think it's fair to say that most potential methods to obtain this …
Likes Hill
  • #38
Dale said:
"As measured in any inertial frame of reference, light is always propagated in empty space with a definite velocity c ..."
Such measurements can only use the two-way speed of light to check the definition of 1 meter. And what means "in" any inertial frame?
In the following quote, "free-float frames" does not exclude non-orthonormal coordinate systems.
Spacetime Physics Chapter 3 said:
3.3 WHAT IS THE SAME IN DIFFERENT FRAMES
One basic physical constant appears in the laws of electromagnetism: the speed of light in a vacuum, c = 299,792,458 meters per second. According to the Principle of Relativity, this value must be the same in all free-float frames in uniform relative motion. Has observation checked this conclusion? Yes
Source:
https://www.eftaylor.com/spacetimephysics/03_chapter3.pdf
Spacetime Physics Chapter 2 said:
A reference frame is said to be an “inertial” or “free-float” or “Lorentz” reference frame in a certain region of space and time when, throughout that region of spacetime — and within some specified accuracy — every free test particle initially at rest with respect to that frame remains at rest, and every free test particle initially in motion with respect to that frame continues its motion without change in speed or in direction
Source:
https://www.eftaylor.com/spacetimephysics/02_chapter2.pdf
  • #39
Yes, it does, because it says the speed of light is ##c## in all such frames. In a non-orthonormal coordinate system, the speed of light will not always be ##c##; it will depend on direction.
  • #40
The quotes you give do not restrict "the speed of light" to two-way measurements.
  • #41
They don't say explicitly "One-way-coordinate speed". The two-way-speed of light does not depend on direction in a non-orthonormal coordinate system. And they refer to observations.
The one-way speed cannot be observed.
  • #42
They don’t have to. That is what the word “speed” means by itself.
Likes PeterDonis
  • #43
Apart from anything else, if the derivation meant something other than an isotropic one-way speed of light, the result would not be the usual Lorentz transforms. It'd be something that, in matrix form, looks like ##S\Lambda S^{-1}##, where ##\Lambda## is the Lorentz transforms and ##S## is the Jacobean matrix transforming from the usual orthonormal coordinates to the skewed coordinates you get from a non-isotropic one way speed of light.
Likes Sagittarius A-Star
  • #44
Yes, but if they had, that would have been more specific and clear. In the cited chapter 2, they use “inertial frame” and “free-float frame” as synonyms.
  • #45
  • Wow
  • #46
Orodruin said:
... the most trustable source of information on the internet after ChatGPT ... 😬
Wikipedia is generally pretty good. Not perfect but good. It is particularly good at getting the standard or common view of things.
  • #47
The common view is not always what is desirable. Just look at ChatGPT, which essentially learns from the common view (although it is on a different level of wrong). Care is needed particularly in advanced subjects.
  • #48
No, but that is specifically what I cited it for. I said “the usual modern formulation” which is precisely what Wikipedia best represents.
I know there is a lot of Wikipedia antagonism in the community, not just here but elsewhere too. I am not persuaded. Wikipedia is a tool and like any tool it has imperfections but it is useful for some tasks and not useful for others. I assert that it is useful specifically for the purpose for which I used it in this thread.
If you have some other source that captures “the usual modern formulation”, such as a meta-analysis or a survey of many scientists or authors, then present it. Trying guilt-by-association with ChatGPT is unconvincing.
Likes PeroK
  • #49
Sorry. I had you confused with the OP. My apologies.
  • #50
I think you will be hard pressed to find any source that discusses oblique coordinates, whether calling them inertial or not - and for obvious reasons. They are simply not very useful. I will repeat however that oblique coordinates would satisfy the requirements on an inertial coordinate system as specified by Newton's first law, the original meaning.* That it is has become common to equate inertial frames to Minkowski frames is not very surprising as it tends to be the only type of frame one considers in most treatments of SR. Einstein, however, did not mention the words "inertial frame" at all in the 1905 paper.
* Of note is that the Galilean transformation - being linear - of course does specify a set of oblique coordinates on Minkowski space (assuming that either the primed or unprimed coordinates belong to a Minkowski frame). Of course, we do not use such coordinates for obvious reasons.
  • #51
I found a short survey and a citation of Edwards in Wikipedia, which includes "two (inertial) coordinate systems". I cannot check if the citation, including "inertial", is correct because the cited paper is not freely available online:
Wikipedia said:
For instance, Edwards replaced Einstein's postulate that the one-way speed of light is constant when measured in an inertial frame with the postulate:
The two-way speed of light in a vacuum as measured in two (inertial) coordinate systems moving with constant relative velocity is the same regardless of any assumptions regarding the one-way speed.[47]​
Source:
https://en.wikipedia.org/wiki/One-w...ansformations_with_anisotropic_one-way_speeds
Abstract of cited paper [47]:
https://pubs.aip.org/aapt/ajp/artic...-in-Anisotropic-Space?redirectedFrom=fulltext
Likes Dale
  • #52
I found a short survey and a citation of Edwards in Wikipedia, which includes "two (inertial) coordinate systems". I cannot check if the citation, including "inertial", is correct because the cited paper is not freely available online:Source:
I didn’t see any survey, just Edwards. I see no indication whatsoever that the common usage of the term “inertial frame” includes anisotropic synchronization conventions.
That is all I am claiming.
Using another convention than the common one is liable to bring confusion, as I mentioned back on the previous page. I never claimed that nobody does it, just that it is a source of confusion and I recommend against it. I hold to that position.
As far as I can tell there are at least three modern meanings of the term “inertial frame”:
1) Newton’s 1st law holds. Non-interacting objects move in a straight line at constant speed.
2) The laws of physics have their simplest form.
3) The two postulates hold. Equivalently, the metric is ##ds^2=-c^2 dt^2+dx^2+dy^2+dz^2##
These are not equivalent. 1) implies that the transformation between inertial frames is any affine transformation. 2) simply makes me uncomfortable because I feel that the simplest form is in terms of differential forms or tensors which gets rid of the concept of frames entirely. So 3) is my preference and recommendation, particularly since it is the common modern view. Using one of the other definitions is not wrong, per se, but does invite miscommunication.
  • #53
Sorry that I didn't link to that subtopic directly: "Inertial frames and dynamics". From there, the document [24] is linked to (The author writes: "I thank John Stachel and Ronald Anderson for discussions and helpful comments. I also thank Hans Ohanian and Michel Janssen for their useful comments"):
https://web.archive.org/web/2012090...aam829/1/m/Relativity_files/Conventions-1.pdf
But I didn't find that very useful.
If true, then the 2nd postulate in most SR books tacitly assumes Einstein-synchronization and is therefore not a valid argument against deviate for the "non-orthonormal inertial coordinate-system" from the standard terminology and re-formulate the 2nd postulate and LT according to Edwards.
I prefer (1) because in common language "inertial" means something physical, while the synchronization convention is something mathematical.
See also:
Wikipedia said:
In classical physics and special relativity, an inertial frame of reference (also called inertial space, or Galilean reference frame) is a frame of reference not undergoing any acceleration. It is a frame in which an isolated physical object—an object with zero net force acting on it—is perceived to move with a constant velocity or, equivalently, it is a frame of reference in which Newton's first law of motion holds.[1] All inertial frames are in a state of constant, rectilinear motion with respect to one another; in other words, an accelerometer moving with any of them would detect zero acceleration.
Source:
https://en.wikipedia.org/wiki/Inertial_frame_of_reference
I think that common SR books invite miscommunication and misunderstanding if they deviate from common language (see above) and use "inertial frame" instead of specifically "orthonormal inertial coordinate system" when applying the usual LT.
Einstein avoided this by using for a good reason the complicated formulation according to option (2).
  • #54
(1), plus an assumption of isotropy works, includes both Galilean and Einsteinian relativity, and enforces orthogonal coordinates in the latter case. (3) excludes Galilean relativity. I'm not sure if that was your intent or not.
Likes Dale
  • #55
Hill said:
I think that the clock that has moved will necessarily lag.
Dale said:
IF they were initially synchronized, yes.
They both moved relative to others frame of reference, as phinds pointed out in in #14.
  • #56
Yes, of course. And in each frame of reference, the one that moves in that frame of reference lags relative to the one that is at rest in that frame of reference.
  • #57
There is also the consequence that taking only 1) violates 2). The laws of physics no longer have their simplest form when written in terms of the coordinates. Straight lines at constant speed also constrain the synchronization convention, so I don’t think that specific distinction is as stark as you suggest.
That is a fair criticism. Unfortunately, the same word does have different meanings in different fields of study. This inevitably does lead to misunderstanding for students. I think this is unavoidable because the differing meanings are so entrenched in each separate field.
In a relativity context I would recommend 3) to avoid miscommunication, but in a Newtonian context I would recommend using a Newtonian meaning for the same reason.
Einstein didn’t have a choice. The modern relativistic definitions didn’t exist before he developed relativity. A seminal author gets the first word on the theory that bears their name, but they do not have the last word.
Not tacitly, but explicitly and deliberately.
and is therefore not a valid argument against …
Of course it is valid. Definitions are tautologically valid by definition.
Likes PeroK
  • #58
Yes. I did not formulate this correctly. Such a constraint is contained in Rindler's SR book in the definition of "inertial frame":
Do you agree, that this definition of "inertial frame" can be fulfilled by a clock synchronization based on anisotropic one-way-speed of light?
Do you think, that Rindler's following conclusion from the 2nd postulate contradicts the definition in the above scan?
Rindler didn't mention here, that the MM experiment tested only the direction-independence of the two-way-speed of light.
  • #59
It allows anisotropic OWSOL conventions that are spatially and temporally homogenous, but it forbids spatially or temporally varying OWSOL conventions. That is the mathematical restriction I was referring to above. Your objection to 3) on the grounds of it being “something mathematical” rather than physical applies to 1) also.
  • #60
Yes, that is intentional, particularly in the metric-based version which is my preference.
