MHB Closure of a Subgroup of GL(2,C)
  • Thread starter Thread starter Advent
    closure Subgroup
Advent
Let $$GL(2;\mathbb{C})$$ be the complex 2x2 invertible matrices group. Let $$a$$ be an irrational number and $$G$$ be the following subgroup
$$G=\Big\{ \begin{pmatrix}e^{it} & 0 \\
0 & e^{iat}
\end{pmatrix} \Big| t \in \mathbb{R} \Big\}$$
I have to show that the closure of the set $$G$$ is
$$\bar{G}=\Big\{ \begin{pmatrix}e^{it} & 0 \\
0 & e^{is}
\end{pmatrix} \Big| t \in \mathbb{R}, s \in \mathbb{R} \Big\}$$
I don't know even how to start. I'm afraid my topolgy knowledge needs serious improvement, but I didn't think it was necessary since I picked up a Group Theory book (Lie Groups, Lie Algebras and their representations: An elementary introduction by Brian C Hall). It sad because the books looks fascinating​
0 & e^{iat}
0 & e^{is}
Obviously $G \subseteq \bar{G}$, so you need to show that every element in $\bar{G}$ can be approximated by an element of $G$. The elements $\begin{bmatrix}e^{it} & 0 \\ 0 & e^{iat}\end{bmatrix}$ and $\begin{bmatrix}e^{it} & 0 \\ 0 & e^{is}\end{bmatrix}$ have the same entry $e^{it}$ in the top left corner, and the value of this element is unchanged if we replace $t$ by $t+2n\pi$. Also, the value of $e^{is}$ is unchanged if we replace $s$ by $s+2m\pi$. So can you choose $n$ and $m$ in such a way that $a(t+2n\pi)$ is close to $s+2m\pi$?
Hint: To do that, use Hurwitz's theorem.
So you use that the closure of a set is itself plus its boundary? Let me explain it myself to see if I'm understanding this: Because $$G \subseteq \bar{G}$$ we only need to compute the boundary part.
Now we want to see if the number $$\frac{a(t+2\pi n)}{s+2\pi m } << 1$$ but I can't put that expression in the form $$\left| \xi-\frac{p}{q} \right|$$ to use the theorem
One way to show that a set $B$ is the closure of a subset $A$ is to check that (i) every point of $B$ is a limit of a sequence in $A$ (and is therefore in either $A$ or the boundary of $A$), and (ii) $B$ is closed. In my previous comment I suggested that you should prove (i) but I neglected to say that you should also check that the set $\bar{G}$ is closed.
Look at the difference rather than the quotient. You want to find $m,\,n$ such that $a(t+2\pi n) \approx s+2\pi m$, or in other words $s-at \approx 2\pi(an-m).$ Now notice that if $\left|a-\frac mn\right| < \frac1{n^2}$ then $|an-m| < \frac1n.$
I will think about your post and reply here later, thank you very much.
I understand your proof and the closure of $$\bar{G}$$ follows quite easily just by multiplying the matrices, however I'm not quite convinced on the solution of this exercise. I'm quite grateful on your help, but I think I need to study some prerequisites of this book and in mathematics in general, say set theory, topology and even some number theory. My math knowledge comes from physics, so I'm not very familiar to the level of rigor required, this is somethin I want to put some effort into too.
I wanted to study group theory because in my general relativity course we were studing the mathematical properties of the Lorentz Group, and I found all of that fascinating.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
