Clovis's question at Yahoo Answers (bounded sequence)
  • MHB
  • Thread starter Fernando Revilla
  • Tags
    Sequence
In summary, a bounded sequence that has no maximum and no minimum element can converge, but only if it is constant. Otherwise, it will have two subsequences approaching different values, indicating that it does not converge.
Fernando Revilla
MHB
631
Here is the question:
Construct a bounded sequence that has no maximum and no minimum element. Could a sequence like this converge? Why or why not?
Here is a link to the question:
Real Analysis Sequences 10pts? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Clovis,
Consider the sequence $a_n=\dfrac{(-1)^nn}{n+1}$. Easily proved, $-1\leq a_n\leq 1$ for all $n$ and the sequence has no maximum and no minimum element.
Now, suppose $x_n$ is bounded sequence, then it has a infimum $m$ and a supremum $M$. If $x_n$ has no maximum and minimum, it has infinitely many elements close both infimum and supremum, so we can construct two subsequences $x_{n_k}\to m$ and $x_{n_r}\to M$. But $m\neq M$ (otherwise, $x_n$ would be a constant sequence, i.e. with maximum and minimum). This means that $x_n$ does not converge.
FAQ: Clovis's question at Yahoo Answers (bounded sequence)
What is a bounded sequence?
A bounded sequence is a sequence of numbers that are limited or confined within a specific range. This means that the values in the sequence cannot exceed a certain upper or lower bound.
What is the importance of Clovis's question about bounded sequences at Yahoo Answers?
Clovis's question at Yahoo Answers is important because it highlights the concept of bounded sequences and the relevance of understanding them in various scientific and mathematical fields, such as calculus, statistics, and physics.
How do bounded sequences differ from unbounded sequences?
Bounded sequences have a defined range of values, while unbounded sequences have no specific limit or boundary. This means that the values in unbounded sequences can continue infinitely without being confined to a certain range.
Can you give an example of a bounded sequence?
One example of a bounded sequence is the sequence of even numbers between 0 and 10. The values in this sequence are limited to the range of 0 to 10 and cannot exceed these bounds.
Why is it important to understand bounded sequences in scientific research?
Bounded sequences are important in scientific research because they allow for the analysis and prediction of data within a specific range. This helps in making informed decisions and drawing accurate conclusions based on the limitations of the data being studied.
