- 919
- 615
I have been debating with a friend about a thought experiment that evolved out of an entirely unrelated discussion, but which has now become a subject of argument.
Consider a "dual" phased array antenna that has every odd-numbered radiating element driven from input port 1 and every even-numbered element driven from input port 2. Essentially, we have two phased array antennas that are 'co-located' or interleaved, so that their radiation patterns coincide, or at least their main radiation lobes coincide. The excitation is such that the main radiation pattern (normal to the array plane) is approximately Gaussian, for example.
Is it possible to achieve the following:
1. Isolation between port 1 and port two of the order of 20 dB or better. That is, sending power down port 1 with port 2 terminated will result in less than a hundredth of the power reaching the termination. The reflected power in a port (return loss) is also 20 dB down.
2. The radiation patterns of the two antennas are nearly identical to the extent that the amplitudes in any direction differ by less than 0.5 dB and the phases match within 5 degrees (these are just to give a sense of the orders of magnitude).
We are concerned mainly with fundamental constraints like reciprocity and conservation of energy. Would the above specs violate these principles?
