CO2 laser recirculation compressors and coolers
Overall, in order to achieve a 20 Kw or higher IR laser, recirculation is necessary and these options would be suitable for your needs.
rppearso
204
Does anyone know what the best recirculation compressors are for a high power CO2 laser. I would like a small foot print low flow positive displacement compressor (rotary vane or diaphragm maybe?) that is not an expensive noisy monstrosity for maybe a $100 or so. Also does anyone know of a good cooler unit that takes regular automotive refrigerant or other commonly available refrigerants that is also small and low profile also that is not terribly expensive.
I have been finding through reading that it will be impossible to achieve a 20 Kw or higher IR laser without recirculation.
Thank you,
Ron
For recirculating compressors, I would recommend the rotary vane compressor. It is a reliable and cost effective option for powering a high power CO2 laser. These compressors are typically small in size and can be mounted on to a wall or ceiling. As far as coolers are concerned, you might consider an air cooled unit that uses a condenser and evaporator to cool the CO2. These units are generally low profile and can be mounted on a wall or ceiling. They use a refrigerant such as R134a, which is commonly available.
FAQ: CO2 laser recirculation compressors and coolers
1. What is a CO2 laser recirculation compressor and cooler?
A CO2 laser recirculation compressor and cooler is a specialized device used in CO2 laser systems to recirculate and cool the gas used in the laser. This helps maintain the stability and efficiency of the laser, allowing for more precise and consistent laser output.
2. How does a CO2 laser recirculation compressor and cooler work?
The compressor and cooler work by compressing and cooling the CO2 gas used in the laser. This is achieved through a series of mechanical and thermal processes, which are carefully controlled to maintain the desired gas pressure and temperature within the laser system.
3. What are the benefits of using a CO2 laser recirculation compressor and cooler?
There are several benefits to using a CO2 laser recirculation compressor and cooler. These include improved laser stability and efficiency, longer lifespan of the laser system, and the ability to maintain precise control over the laser output. Additionally, the compressor and cooler can help reduce operating costs by using less gas and eliminating the need for frequent gas refills.
4. Are there different types of CO2 laser recirculation compressors and coolers?
Yes, there are different types of CO2 laser recirculation compressors and coolers available on the market. These can vary in terms of their design, size, and capabilities. It is important to choose a compressor and cooler that is specifically designed for your CO2 laser system to ensure optimal performance.
5. How do I maintain and troubleshoot a CO2 laser recirculation compressor and cooler?
Proper maintenance and troubleshooting of a CO2 laser recirculation compressor and cooler is crucial for ensuring its optimal performance. This may include regularly cleaning and replacing filters, checking and adjusting gas pressure and temperature, and monitoring any potential issues or malfunctions. It is recommended to follow the manufacturer's instructions and consult with a specialist for any troubleshooting or repairs.
