mcubed45
- 4
In the planted aquarium hobby, CO2 is often infused into the aquarium water using a compressed cylinder of CO2 which runs through a regulator, a needle valve, a bubble counter, and then into the tank. At the end of the gas line, a diffuser is used. The diffuser is porous ceramic material which permits tiny bubbles of CO2 to permeate into the water when sufficient pressure is applied.
My question is whether the working line pressure affects the density of the CO2 gas in the line. Bubble counters are used as a visual means to gauge how much gas is being delivered to the aquarium and gives an easy references for titrating up or down to meet the needs of the plants. Will the bubble counter still accurately reflect the quantity of gas being delivered when a different working pressure is used?
Some newer diffusers have come into the market that require a working pressure of at least 30 psi. Previous diffuers typically required only about 10-15 psi. The company claims that because only half as many bubbles per second (bps) are being used to achieve the same level of CO2 saturation, only half as much CO2 is being consumed. Is this accurate or does the change in working pressure need to be factored in? Does a single bubble in the bubble counter at 15psi contain the same quantity of CO2 at 30psi?
