Coal needed to produce 100000 BTU/s
  • Thread starter noxnoxmox
  • Tags
    Coal
In summary, in a typical house, it would require approximately 10 pounds of coal per hour to produce 100,000 BTU/s. The energy density of coal varies depending on the type, with Pennsylvania anthracite having a higher specific heat than Texas brown coal. It is important to know the specific heat of the coal being used in order to accurately determine the amount needed.
noxnoxmox
how much coal is required to produce 100000 BTU/s in a typical house?
I have been looking and looking with no leads on it
need help please
I am a plumbing, heating, and cooling contractor in Maine. 100,000 btu/hr is normal for a house up here with a -10 design temp. We use 12,000 btu's per lb for bulk or bag coal. It has always worked for us.
The specific heat of coal varies all over the map. Really good Pennsylvania anthracite (virtually unavailable now) was as high as 17,000 btu/lb, while some Texas brown coal is as low as 2500 btu/lb. Be sure to get the correct specific heat for the coal you plan to use.
Related to Coal needed to produce 100000 BTU/s
1. How much coal is needed to produce 100000 BTU/s?
The amount of coal needed to produce 100000 BTU/s will vary depending on the type of coal being used and the efficiency of the power plant. On average, it takes approximately 0.02-0.03 pounds of coal to produce 100000 BTU/s.
2. What is the energy output of 1 pound of coal?
The energy output of 1 pound of coal can vary depending on the type of coal, but on average, 1 pound of coal can produce 9000-10000 BTU (British Thermal Units) of energy.
3. How does coal produce 100000 BTU/s of energy?
Coal is a fossil fuel that contains energy stored from millions of years ago. When coal is burned, it releases heat energy in the form of 100000 BTU/s. This heat energy is then used to power turbines and generate electricity.
4. What are the environmental impacts of using coal to produce 100000 BTU/s?
The use of coal to produce 100000 BTU/s of energy can have negative impacts on the environment. Coal mining can lead to air and water pollution, and the combustion of coal releases greenhouse gases into the atmosphere. It also contributes to climate change and can have harmful effects on human health.
5. Is there a more sustainable alternative to using coal for energy production?
Yes, there are several sustainable alternatives to using coal for energy production, such as renewable energy sources like solar, wind, and hydropower. These sources do not emit greenhouse gases and have a much lower impact on the environment. However, transitioning to these alternatives may require significant investments and changes in infrastructure.
  • General Engineering
  • Earth Sciences
  • Mechanical Engineering
