Coastal Civil/Structural Engineering - Infrastructure Stability
  • Thread starter Thread starter Astronuc
    california
A section of California's coastal highway has collapsed, stranding hundreds of motorists. The area is prone to erosion due to its location on a sandstone cliff, which becomes unstable when saturated with rain. Historical erosion has likely reduced the cliff's size, and ongoing wave action will continue to push the coastline inland. There are calls for better planning in road construction, suggesting that new transport links should be built inland to avoid similar risks. The discussion highlights the challenges of infrastructure stability in California's dynamic geological landscape.
Astronuc
Staff Emeritus
Once again, a part of a highway along the coast in California has collapsed. Folks like having a view of the ocean while driving - although the driver is supposed to be watching the road for curves, wildlife and oncoming traffic.
Hundreds Stranded as Part of California Coastal Highway Collapses
https://news.yahoo.com/hundreds-stranded-part-california-coastal-101901797.html
Who thought is a good idea to build a highway on a sandstone cliff, and it's hardly sandstone, but more like compacted ground, which when wet, or rather soaked, by rain is likely to collapse - as is not uncommon in such area along the west coast. There was a retaining wall, but much of the ground underneath fell away.
I suspect that at one time, there was more cliff there than there is now. In time, the cliff will likely reach the inland side of the road. A combination of wave action and periodic heavy rains means the coast line will move inland eventually, as California is learning the hard way.
Likes russ_watters and Lnewqban
Yeah, 3 roads in a big city park next to us here in the foothills above Silicon Valley have been washed out partially by the big rain storms of the past few years. Two of them have been repaired but are still closed to auto traffic, and the 3rd is not repaired but has 1-way traffic controls via automated signal lights now. It will be pretty hard to repair since part of the road collapsed into the creek that runs right next to the road (much like the picture in your post above, just not as far down to the creek).
Hopefully road planners will do a better job going forward thinking about where to run new roads...
Likes russ_watters
One thing is certain, cliffs represent an active erosion landscape. The slope of the land determines the energy available for erosion when it rains. Given time, the sea will undermine whatever is built.
The coast road should be restricted to local access. Transport links should be located inland, where risk and engineering costs are less, as there is more ground stability.
Hey folks!
This is California, the Earth here moves in all 3 dimensions without notice. We deal with it.
(It helps build our hubris, you see. :wink:)
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
10K
